Home > Technical (L322) > Releasing Connector
GUMBALLER
Releasing Connector
Hi.
Can anyone tell me how these connectors release please.
Thanks
Post #645281 10th Oct 2022 4:43pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
I *think* you push it sideways and as it slides across, it rises and separates - you can see the pegs / ramp on the side.
Post #645291 10th Oct 2022 5:51pm
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
I think there is locking-system missing already. Just pull it uot.
Post #645292 10th Oct 2022 6:04pm
24valve
United Kingdom 2010 Range Rover Autobiography Black TDV8 Santorini Black
they can be a pain, but as per previous posts it slides across and releases at the same time. If its a bit tight, get a screwdriver and wedge it in the gap between the bit that slides and the plug at the end. 2010 L322 Autobiography Black Edition
1975 Land Rover
Post #645293 10th Oct 2022 6:22pm
bebechoon
France
Is that on the Body Control Unit?
If so, pics of this connector in my BCM replacement write-up (in the WiKi):
https://www.fullfatrr.com/forum/topic40009.html
Hope it helps!
 It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #645388 11th Oct 2022 4:13pm
GUMBALLER
Thanks for your replies.
You just have to have a strong grip and be brutal sliding it
Post #645437 12th Oct 2022 12:21pm
