Home > Technical (L322) > Remote heater issue |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7801 |
6th Oct 2022 12:59pm |
Woodysjw Member Since: 19 Sep 2022 Location: Essex Posts: 12 |
Yes that’s different to my remote,
6th Oct 2022 1:03pm |
The manual is in the Wiki if it’s any use, but I’d say you need a T91.
6th Oct 2022 1:08pm |
Don’t know mate. Won’t get to the car till later, but mines a 2011 and factory fit.
6th Oct 2022 1:09pm |
https://www.fullfatrr.com/forum/topic47265.html?highlight=t91
6th Oct 2022 1:15pm |
Looks like I have a T91r and definitely need a T91
6th Oct 2022 1:33pm |
You could put a Wanted ad in the For Sale section.
6th Oct 2022 1:46pm |
Thanks mate,
6th Oct 2022 2:00pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1468 |
Just before you do...
6th Oct 2022 2:45pm |
Ok thanks will do
6th Oct 2022 3:26pm |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 276 |
I’ve been through exactly this issue in the last month. I have a 2012 TDV8 Vogue. Having done research on the forum I ordered two fobs from eBay at different times neither of which would pair. In the end I ordered the LR OEM fob from Rob at Duckworth’s having supplied my Reg No. it cost 2x of the eBay ones but paired first time. Below is the fob part number that worked for me and the unit installed in my car. Hope that helps. BTW; when you get it sorted post back on what worked for you to help in the future.
6th Oct 2022 8:49pm |
Thank you that’s just the info I was looking for
6th Oct 2022 10:09pm |
I recommend checking the part number thoroughly as I bought a T91 ( i.e. not the R ) secondhand from eBay and it failed to pair. I determined that there may be several types of T91 that vary by part No. so uou can’t go by how it looks. TDV8 4.4 2012 |
6th Oct 2022 11:26pm |
I've been doing some digging on this one.
7th Oct 2022 12:09am |
