Home > Technical (L322) > Remote heater issue
Woodysjw
Remote heater issue
Hi
I have a 2012 Westminster 4.4tdv8 with remote fuel burn heater,
Unfortunately it has no remote, and after searching I see there are different remotes and receivers.
I checked my module and it’s a T91R 8h52 18d540 ac,
I then ordered a t91r remote the one with off and the heat/fan symbol.
I think this is the issue as I can’t pair it, despite the videos guides etc.
Does anyone else have a L322 2012 t91r with working remote if so what remote do you have please?
Thanks
Woody
Post #644905 6th Oct 2022 12:53pm
mjdronfield
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #644906 6th Oct 2022 12:59pm
Woodysjw
Yes that’s different to my remote,
Is your controller a t91r?
Post #644907 6th Oct 2022 1:03pm
mjdronfield
The manual is in the Wiki if it’s any use, but I’d say you need a T91.
Sure there was a thread fairly recently about the remotes….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #644908 6th Oct 2022 1:08pm
mjdronfield
Don’t know mate. Won’t get to the car till later, but mines a 2011 and factory fit.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #644910 6th Oct 2022 1:09pm
mjdronfield
https://www.fullfatrr.com/forum/topic47265.html?highlight=t91
https://www.fullfatrr.com/forum/topic58215.html?highlight=t91
https://www.fullfatrr.com/forum/topic57756.html?highlight=t91 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #644913 6th Oct 2022 1:15pm
Woodysjw
Looks like I have a T91r and definitely need a T91
Does anyone have one for sale?
Post #644917 6th Oct 2022 1:33pm
mjdronfield
You could put a Wanted ad in the For Sale section.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #644918 6th Oct 2022 1:46pm
Woodysjw
Thanks mate,
I just tried, not enough posts yet
Post #644919 6th Oct 2022 2:00pm
garyRR
Just before you do...
I have the remote for my FBH but I couldn't get it working. Despite the remote lighting up and everything, it would just not pair.
So, I changed the battery and low and behold, it worked immediately. It seems these remotes need a very exact 3V from the battery or they will light up as if they're working, but not power their transmitter.
If you've already tried a new battery then, I think it's a case of try a T91 remote (or see below) but if you haven't, I'd try a battery first, as it's a cheap option. This is the battery I ordered:
VARTA Batteries Electronics CR1/3N Lithium button cell 3V battery 1-pack, Button cells in original blister pack of 1 https://amzn.eu/d/fbjc0tu
Your alternate option:
Set up your own WiFi or Bluetooth switch, which is very easy to do and then, you can heat your car from your phone instead of having to carry around a separate remote. Here's some inspiration:
https://motor-roam.co.uk/l322-range-rover-...-10-pounds 2015 Range Rover Autobiography 4.4 SDV8
Post #644924 6th Oct 2022 2:45pm
Woodysjw
Ok thanks will do
The other option looks great but I am a sucker for OEM
Post #644927 6th Oct 2022 3:26pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Re: Remote heater issue
Woodysjw wrote:
Hi
Woody
I’ve been through exactly this issue in the last month. I have a 2012 TDV8 Vogue. Having done research on the forum I ordered two fobs from eBay at different times neither of which would pair. In the end I ordered the LR OEM fob from Rob at Duckworth’s having supplied my Reg No. it cost 2x of the eBay ones but paired first time.
Below is the fob part number that worked for me and the unit installed in my car. Hope that helps.
BTW; when you get it sorted post back on what worked for you to help in the future.
 TDV8 4.4 2012
Post #644971 6th Oct 2022 8:49pm
Woodysjw
Thank you that’s just the info I was looking for
You have the same controller as mine, T91R but still needs a T91 remote
Post #644973 6th Oct 2022 10:09pm
Ramblin Man
I recommend checking the part number thoroughly as I bought a T91 ( i.e. not the R ) secondhand from eBay and it failed to pair. I determined that there may be several types of T91 that vary by part No. so uou can’t go by how it looks. TDV8 4.4 2012
Post #644976 6th Oct 2022 11:26pm
garyRR
I've been doing some digging on this one.
Theres 2 different remotes listed for the 2010-2012 (and both look the same so, make sure you go by chassis number):
LR009736 - Chassis AA000001 - BA336892
LR027493 - Chassis BA336893 -
There are also 3 different variants of the Telestart unit:
LR009687 - Chassis AA000001 - BA342419
LR027067 - Chassis BA342420 - CA368914
LR036696 - Chassis CA368915 -
My vehicle is BA3363... .Seeking a T91 or T91R remote might be a red herring because the above numbers have to mean what you think is a T91R remote was in use on vehicles that still had a T91 Telestart (because mine has a T91 Telestart and is in that first camp), because the later remote number started on chassis before the change in part number of the Telestart.
I think the more likely reason some people have had problems buying 2nd had ones is because the remotes are locked to a range of serial numbers (or the Telestarts are) and that potentially also explains why there isn't a single aftermarket supplier of OE Webasto remotes and programming out there. If you buy a 2nd hand Land Rover remote from a 2010-2012 vehicle, you've got a 50/50 chance of it being correct for your vehicle. You can probably increase those odds by assuming BA336892 is as far as Q1 2011 amd BA336893-> are anything after that date and therefore getting a remote from a similarly registered vehicle as yours. Part numbers before 2010 were entirely different and the remote also looked different. 2015 Range Rover Autobiography 4.4 SDV8
Post #644977 7th Oct 2022 12:09am
