![]() | Home > Maintenance & Mods (L405) > Battery charging |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1311 ![]() ![]() |
I have been using the CTEK charger for over 18 months, with no issues. I use it to top up when I get the "start the engine message battery low" |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 791 ![]() ![]() ![]() |
I charge my main battery by connecting directly to it in the boot, using both a Ctek and a solar charger. I’ve used this technique on 3 different L405’s (MY’s 15,16 & 19) for many years without problem.
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1247 ![]() ![]() |
Another aside!
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
I connect positive first. Reasoning if you connect negative first then there is the chance of the positive, whilst disconnected, touching bodywork or engine parts causing a short circuit. That’s my reasoning. It shouldn’t happen if you don’t switch on power to the charger before everything is connected but no harm in being sure. lol John
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
The reasoning behind +ve first connecting up, last when disconnecting stems from the possibilities of gas from the battery. In connecting up, +ve goes onto the battery post and the negative to metalwork away from the battery, if there's a spark it doesn't matter. When disconnecting the opposite, it true, negative first away from the battery etc. BMW i3 Electric Car
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1666 ![]() ![]() ![]() |
[quote= The reasoning behind +ve first connecting up, last when disconnecting stems from the possibilities of gas from the battery. In connecting up, +ve goes onto the battery post and the negative to metalwork away from the battery, if there's a spark it doesn't matter. When disconnecting the opposite, it true, negative first away from the battery etc./quote]
Blimey, could you call my missis tonight and tell her actually I was right |
@AJGalaxy2012:
