Home > Maintenance & Mods (L405) > Battery charging
Gremlin500
We must all remember the purpose of this forum is to help one another as Brothers in Arms above all else, and generally that is what I have found on this “Gentlemans’ Forum” and long may it continue. Thumbs Up
I am no expert on automotive battery charging issues I have to say and have merely reported others’ findings as impassively as possible above, however as a professional engineer of more than 40 years have researched battery technology extensively as a builder and user of ebikes. One possible caveat to the “charging from the other end” brigade is the possible effect on the BMS (Battery Monitoring System). JLR WM actually recommends “removing the battery from the vehicle” before charging. Yeah, right.
However, most of us know it’s proven to be OK to charge using a smart charger (CTEK or otherwise) connected to the underbonnet posts. Without knowing the logic of the BMS, it’s very difficult to say what might upset it, or cause damage if charging from the “other end” which may confuse /destroy the BMS, -I honestly don’t know, but is it worth taking the risk, or am I thinking BS?
So, until anyone can quote a “Scholarly Paper” explaining otherwise, I will not use the “recon” mode of my CTEK on my brand new and not inexpensive AGM battery. Shocked “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #644802 4th Oct 2022 10:43pm
Kot
I have been using the CTEK charger for over 18 months, with no issues. I use it to top up when I get the "start the engine message battery low" Rolling with laughter I use the extension lead and use the connections under the bonnet as well. I use the crocodile clips with no issues.
I did have the same set up on the DS but hard wired it direct to battery with a short lead that fitted to the extension lead, again no issues.
Its not often I need to use it (maybe every 3 months or so) my dash cam is a slight drain as it activates when raining or a leaf dropping (I really need to adjust the sensitivity Rolling with laughter ) and my rural journey dont really keep up with the slight loss over time. 2018 SE SDV8 4.4 Byron Blue
Post #644813 5th Oct 2022 7:58am
Phil.
I charge my main battery by connecting directly to it in the boot, using both a Ctek and a solar charger. I’ve used this technique on 3 different L405’s (MY’s 15,16 & 19) for many years without problem.
This will probably give a few people on here a heart attack Smile MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #644834 5th Oct 2022 12:19pm
Bill
Another aside!
Noting an early post about connecting live first,
On my grasscutter…. I connect the charging unit in any old order… so it’s 50/50 which gets connected first.
Does that matter? If so why?
Now I think about it , post covid, my wife’s car stood idle & again didn’t think about the order of connection. Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #644837 5th Oct 2022 12:55pm
Weegie
I connect positive first. Reasoning if you connect negative first then there is the chance of the positive, whilst disconnected, touching bodywork or engine parts causing a short circuit. That’s my reasoning. It shouldn’t happen if you don’t switch on power to the charger before everything is connected but no harm in being sure. lol John
GAP iiD BT
Post #644841 5th Oct 2022 2:23pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
The reasoning behind +ve first connecting up, last when disconnecting stems from the possibilities of gas from the battery. In connecting up, +ve goes onto the battery post and the negative to metalwork away from the battery, if there's a spark it doesn't matter. When disconnecting the opposite, it true, negative first away from the battery etc. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #644843 5th Oct 2022 2:44pm
Gremlin500
[quote= The reasoning behind +ve first connecting up, last when disconnecting stems from the possibilities of gas from the battery. In connecting up, +ve goes onto the battery post and the negative to metalwork away from the battery, if there's a spark it doesn't matter. When disconnecting the opposite, it true, negative first away from the battery etc./quote]
-This is the real reason, well said! Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #644848 5th Oct 2022 3:31pm
AJGalaxy2012
Blimey, could you call my missis tonight and tell her actually I was right Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter BMW i3 Electric Car
Post #644854 5th Oct 2022 5:45pm
Gremlin500
@AJGalaxy2012:
Call made. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #644865 5th Oct 2022 9:46pm
Gremlin500
Rolling with laughter “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #644866 5th Oct 2022 9:46pm
