Home > Maintenance & Mods (L322) > 4.4 TDV8 EGR and DPF removal
Page 8 of 14 <123 ... 789 ... 121314>
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
telly-addict wrote:
So I got the remap and had the EGR mapped out.
a remap with EGR delete will greatly improve your situation and remove a point of failure for several common faults. Emissions will NOT be affected as the DPF is still very much in use and MOTs are NOT a worry (speaking from experience). Thumbs Up
Thanks for the update @telly-addict, who did the remap ?
And please confirm that you fabricated your own EGR blanking plate.
Thanks. TDV8 4.4 2012
Post #644463 1st Oct 2022 7:50am
JayGee
Just had a quote from SLT of £175 to delete the EGR. 2012 TDV8 Vogue (L322)
Post #644486 1st Oct 2022 2:11pm
JayGee
Just read the workshop manual and it says the ECU uses the EGR valve during regeneration. It opens during overrun as the throttle plate is partially closed during regens and this stops excessive engine braking. It also uses the EGR to help regulate the intake air temperature (I've seen both these on the GAP IID live values BTW) . It would need a very clever remap to delete the valve and if you physically blanked it you would have issues. Also there are other descriptions of how the system carefully controls the burn to specific temperatures and as indicated the EGR valve will likley be part of this. A clever way to reduce intake fouling would be a remap that ran a lower % of EGR gasflow on light throttle / low power but still operated normally during regeneration. I know on some cars they fit restrictor plates that allow just enough egr flow into the intake to not throw a CEL but it's less than stock so fouling is reduced. 2012 TDV8 Vogue (L322)
Post #644573 2nd Oct 2022 1:00pm
telly-addict
Scotland 2011 Range Rover Vogue TDV8 Stornoway Grey
Thanks.
Yes I did indeed make my own blanking plate with 2mm steel sheet Thumbs Up
Oh and it's a Quantum map. Cam
2011 TDV8 Vogue in Stornoway Grey
Post #644606 2nd Oct 2022 10:07pm
telly-addict
Hello again fella, yes I think you're correct wrt the engine breaking as this is a little more pronounced now however I prefer my engines to actually have an effect on the car when I come off the throttle - not being facetious btw, I do actually like the engine breaking effect.
The rest is about unnecessarily regulating the intake temps - think about it, what possible need would the engine have for hot exhaust gases once it's up to temp? And it's up to temp very quickly if your thermostat is working properly. If your EGR is permanently shut, there will be scant reason for the DPF to regen too given that the EGR causes most of the soot buildup.
All the EGR does to a healthy engine is feed it its own excrement whilst cleaning the exit gases a scant amount of HC at the expense of decreased efficiency. Cam
Post #644608 2nd Oct 2022 10:19pm
JayGee
Sorry I should have made it clear in that extract from the WM that the regulation of intake temperature only happens during the regen process and is necessary to prevent damage to the DPF and I don't think the EGR is used to regulate intake temps during normal driving. Did the tuner say to physically blank the EGR as if the throttle plate is still closing on overrun in normal driving it suggests the ecu is still thinking there is an EGR valve. No fuel is burnt on overrun so if the EGR opens it's not contributing to soot and is just an economy feature but as you say a bit of engine braking can benefit drivability. How many miles have you done with this mod and have you monitored the regen frequency and EGR temps during a regen? 2012 TDV8 Vogue (L322)
Post #644613 3rd Oct 2022 6:44am
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Just weighing in here based on my experiences…
I have a 4.4 TDV8 which I have had the EGR valve blanked and mapped out. I debated this for a long time due to the varied opinions on the issues it could cause. I researched as much as I could and, while I am no mechanic or car expert in any way, I felt it was ok to proceed. My understanding was that the EGR valve is used to reduce the “burn temperature” to reduce NOx at the cost of more soot, and also to help reduce the exhaust temp following DPF regenerations.
The theory was that the DPF regen frequency would reduce due to less soot being produced, and as these cars are designed to operate in far hotter countries, there was less of a need to “help” cool the exhaust.
The final nail in the coffin for me was finding a gunked up plenum chamber.
After cleaning that out i found the cars throttle response had improved so wanted to avoid it reoccurring.
As soon as I had mine blanked and mapped out, I noticed the difference immediately. The cars throttle response and pickup was substantially better and the drive just seemed better. (Not scientific i know!).
Does the DPF need a regen as often? I have no idea. I never really noticed it before and continue to not notice now.
However, I removed the plenum over the weekend to check for evidence of boost and oil leaks and noticed that the plenum appeared as clean now as it was when I first cleaned it Thumbs Up
That was about 5,000 miles ago…
Would I recommend others remove their EGRs? Due to the varied opinions on this subject by others far more knowledgable then me… I cannot. That would need to be decided by yourselves based on your own research.
Would I do it again? Absolutely and without hesitation. I love the earlier comment about not feeding the engine its own excrement, and it sums my feelings up perfectly. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #644649 3rd Oct 2022 12:37pm
telly-addict
Yes the EGR is used (along with additional fuel) to increase exhaust temps to facilitate easier regen on the DPF. Does removing one negate the ability of the other to function? Debateable but consider that by removing the EGR, you have removed the primary cause of soot build up in the DPF. Now while I have considered deleting the DPF, with the EGR now doing what it does best (nothing), the DPF is a lot easier to live with.
While no fuel is burnt on overrun, crap is still being recirculated through the engine so a) you're not making any economy savings because no fuel is burnt anyway on overrun whether the EGR is open or not and b) when you go back on the throttle the engine is currently gargling is own toxic non-combustible cocktail and has to clear that first with fresh fuel/air before normal service is resumed thereby lowering efficiency and therefore economy.
The tuner did suggest unplugging the EGR yes to ensure it never engaged, but I never did. However after noticing continuing regens I blanked it off, but a boost leak at the donut pipes may have aggravated the situation so I cannot say for certain that the blank cured that aspect.
I have been running the map since March and done maybe 4k greatly-improved miles since.
Thumbs Up Cam
Post #644656 3rd Oct 2022 1:34pm
JayGee
I have to say that as mine's not far off 150k miles and the price of diesel is not going down the argument for preserving the DPF and increasing mpg is quite persuasive. How much did Quantum charge and was it as part of a performance remap or a standalone thing? 2012 TDV8 Vogue (L322)
Post #644666 3rd Oct 2022 4:19pm
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
How you duys solve/think about next things:
1) Did you install a separate blow-up valve for turbos? Because EGR valve play also blow-up valve role on many diesel engines, incl. 4,4. When you suddenly release accelerator pedal after high performance, EGR valve open immidietly and release the overpressure back to exhaust system via EGR.
2) Is this remapping takes in mind different air flow via MAS sensors? Now, without EGR you have higher air flow from outside due no additional air from EGR valve. Injection should be corrected according that new different airflow as well.
3) What you thinking about higher combustion temperature in combustion chamber, how this effects to pistons and turbos in long term?
Post #644676 3rd Oct 2022 5:57pm
IMHO none of those make any significant difference.... Pete
Post #644682 3rd Oct 2022 7:38pm
Phoenix
They're all valid points though - ones that were taken care of in design, unlikely to be thought of by many of the 'remappers'. Some of them may well take a while to develop issues, some may contribute to know issues like inlet manifold splits earlier than otherwise.
Post #644688 3rd Oct 2022 8:10pm
JayGee
Diesel turbo engines don't need 'Blow-off' / 'dump' valves as the throttle plate doesn't shut when you come off throttle like a petrol engine so there is no intake pressure surge. Although it seems the TP does close if you blank the EGR valve as it tries to increase EGR flow.
Fuelling is controlled via MAP, MAF IAT and oxygen sensor so it will be fine.
Combustion temperatures will be higher with no EGR flow but as the EGR is only open at low load settings it's not likley to overheat. When you put your foot down the EGR closes anyway and EGT and in cylinder temps rise very fast but it's all within the cooling capacity. Imagine lugging a loaded trailer up a steep hill or pushing the brick like body through the air at 140mph on the autobahn - EGR shut by default in those high load situations . 2012 TDV8 Vogue (L322)
Post #644694 3rd Oct 2022 9:47pm
telly-addict
I think standard price was £350 + £50 for the 'economy' remap and EGR delete respectively from the dealer near me (N. Scotland). Power increases by ~70bhp and torque 100nm. Apparently there's a 'balls-out' power remap that makes much more but isn't transmission friendly. Obviously I wasn't interested in that. Cam
Post #644697 3rd Oct 2022 10:04pm
JayGee
Thanks. Could do with a power decrease on mine - wonder if they can map out the 2nd turbo Laughing 2012 TDV8 Vogue (L322)
Post #644713 4th Oct 2022 6:43am
