Home > Maintenance & Mods (L322) > 4.4 TDV8 EGR and DPF removal |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 281 |
Thanks for the update @telly-addict, who did the remap ? And please confirm that you fabricated your own EGR blanking plate. Thanks. TDV8 4.4 2012 |
1st Oct 2022 7:50am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Just had a quote from SLT of £175 to delete the EGR. 2012 TDV8 Vogue (L322) |
1st Oct 2022 2:11pm |
telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 139 |
Yes I did indeed make my own blanking plate with 2mm steel sheet Oh and it's a Quantum map. Cam 2011 TDV8 Vogue in Stornoway Grey Last edited by telly-addict on 2nd Oct 2022 10:20pm. Edited 1 time in total |
2nd Oct 2022 10:07pm |
Hello again fella, yes I think you're correct wrt the engine breaking as this is a little more pronounced now however I prefer my engines to actually have an effect on the car when I come off the throttle - not being facetious btw, I do actually like the engine breaking effect. The rest is about unnecessarily regulating the intake temps - think about it, what possible need would the engine have for hot exhaust gases once it's up to temp? And it's up to temp very quickly if your thermostat is working properly. If your EGR is permanently shut, there will be scant reason for the DPF to regen too given that the EGR causes most of the soot buildup. All the EGR does to a healthy engine is feed it its own excrement whilst cleaning the exit gases a scant amount of HC at the expense of decreased efficiency. Cam 2011 TDV8 Vogue in Stornoway Grey |
2nd Oct 2022 10:19pm |
Sorry I should have made it clear in that extract from the WM that the regulation of intake temperature only happens during the regen process and is necessary to prevent damage to the DPF and I don't think the EGR is used to regulate intake temps during normal driving. Did the tuner say to physically blank the EGR as if the throttle plate is still closing on overrun in normal driving it suggests the ecu is still thinking there is an EGR valve. No fuel is burnt on overrun so if the EGR opens it's not contributing to soot and is just an economy feature but as you say a bit of engine braking can benefit drivability. How many miles have you done with this mod and have you monitored the regen frequency and EGR temps during a regen? 2012 TDV8 Vogue (L322) |
3rd Oct 2022 6:44am |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
Just weighing in here based on my experiences…
3rd Oct 2022 12:37pm |
Yes the EGR is used (along with additional fuel) to increase exhaust temps to facilitate easier regen on the DPF. Does removing one negate the ability of the other to function? Debateable but consider that by removing the EGR, you have removed the primary cause of soot build up in the DPF. Now while I have considered deleting the DPF, with the EGR now doing what it does best (nothing), the DPF is a lot easier to live with. While no fuel is burnt on overrun, crap is still being recirculated through the engine so a) you're not making any economy savings because no fuel is burnt anyway on overrun whether the EGR is open or not and b) when you go back on the throttle the engine is currently gargling is own toxic non-combustible cocktail and has to clear that first with fresh fuel/air before normal service is resumed thereby lowering efficiency and therefore economy. The tuner did suggest unplugging the EGR yes to ensure it never engaged, but I never did. However after noticing continuing regens I blanked it off, but a boost leak at the donut pipes may have aggravated the situation so I cannot say for certain that the blank cured that aspect. I have been running the map since March and done maybe 4k greatly-improved miles since.
3rd Oct 2022 1:34pm |
I have to say that as mine's not far off 150k miles and the price of diesel is not going down the argument for preserving the DPF and increasing mpg is quite persuasive. How much did Quantum charge and was it as part of a performance remap or a standalone thing? 2012 TDV8 Vogue (L322) |
3rd Oct 2022 4:19pm |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 |
How you duys solve/think about next things:
3rd Oct 2022 5:57pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8338 |
IMHO none of those make any significant difference.... Pete
3rd Oct 2022 7:38pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
They're all valid points though - ones that were taken care of in design, unlikely to be thought of by many of the 'remappers'. Some of them may well take a while to develop issues, some may contribute to know issues like inlet manifold splits earlier than otherwise. |
3rd Oct 2022 8:10pm |
Diesel turbo engines don't need 'Blow-off' / 'dump' valves as the throttle plate doesn't shut when you come off throttle like a petrol engine so there is no intake pressure surge. Although it seems the TP does close if you blank the EGR valve as it tries to increase EGR flow. Fuelling is controlled via MAP, MAF IAT and oxygen sensor so it will be fine. Combustion temperatures will be higher with no EGR flow but as the EGR is only open at low load settings it's not likley to overheat. When you put your foot down the EGR closes anyway and EGT and in cylinder temps rise very fast but it's all within the cooling capacity. Imagine lugging a loaded trailer up a steep hill or pushing the brick like body through the air at 140mph on the autobahn - EGR shut by default in those high load situations . 2012 TDV8 Vogue (L322) |
3rd Oct 2022 9:47pm |
I think standard price was £350 + £50 for the 'economy' remap and EGR delete respectively from the dealer near me (N. Scotland). Power increases by ~70bhp and torque 100nm. Apparently there's a 'balls-out' power remap that makes much more but isn't transmission friendly. Obviously I wasn't interested in that. Cam 2011 TDV8 Vogue in Stornoway Grey |
3rd Oct 2022 10:04pm |
Thanks. Could do with a power decrease on mine - wonder if they can map out the 2nd turbo 2012 TDV8 Vogue (L322) |
4th Oct 2022 6:43am |
