Home > Technical (L322) > Tailgate window side trims.
Page 1 of 3 123>
KitTheRam
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
I have the seemingly common problem of unsightly rubber side trims that have twisted away from the glass, especially at the bottom. I have read that these don’t actually do anything? I have found the replacements for £70 but I am wondering the pros and cons to either just getting rid or replacing.
How hard will it be to take them off and is there any specific technique to do so?
Post #644372 30th Sep 2022 8:40am
mjdronfield
They stop any water on the tailgate running inside when you open the tailgate when it’s raining.
On my early car, without them, I got in the habit of opening the tailgate and moving the parcel shelf out the way at the same time so dirty water didn’t go on my ivory shelf….
Folks have removed them, can be tight though.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #644374 30th Sep 2022 9:26am
KitTheRam
Thanks. Thought they would have some sort of purpose.
Out of interest where in Derbyshire are you from? I grew up in Littleover in Derby.
Post #644375 30th Sep 2022 9:31am
kevinp
My car didn't have them on and I was fed up with water dripping on my parcel shelf when opening the tailgate. I put some on a few months back and I'm afraid water still drips in if you open the tailgate quickly!!
Post #644380 30th Sep 2022 9:55am
KitTheRam
Pain in the bum to fit?
Post #644381 30th Sep 2022 10:11am
mjdronfield
I’m in Chesterfield mate.
The strips can only do so much, there are less drips with them on, but they do appear very unsightly when they start to corrode, and not especially cheap to replace.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #644382 30th Sep 2022 10:14am
KitTheRam
Only had the car a week and have a little fund of money for immediate repairs (mostly of stuff that is annoying me). Think I will replace - just hope it’s not a total faff.
Post #644383 30th Sep 2022 10:19am
kevinp
YEP. Especially the bottom 'tongue' bit.
Post #644384 30th Sep 2022 10:21am
p38arover
Australia
My 2003 doesn't have them - at least I don't think so. I'll have a look tomorrow morning. When did they start being fitted? I'll have to look at a later model to see what they look like. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #644397 30th Sep 2022 12:12pm
mjdronfield
They can be seen on the pic on the first post.
Not fitted to the early cars. They had a thick rubber strip at the bottom of the rear screen…. Not fitted to the later cars.
Not sure when they started fitting them… maybe 2008/09?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #644401 30th Sep 2022 12:57pm
KitTheRam
Some closer pictures if useful as to what they are.
Post #644407 30th Sep 2022 1:41pm
G3BML
Scotland 2010 Range Rover Vogue SE TDV8 Santorini Black
Does the glass need to be removed to fit them?
Post #644421 30th Sep 2022 4:12pm
no, the trims slide on ... a bit of fairy liquid will help the fitting. ... - .- -.
Post #644422 30th Sep 2022 4:21pm
KitTheRam
I was wondering if there was ever a lower seal to this rear window when new? Looks like there’s a gap for another strip and a lot of dusty dirt is sitting in there. Needs a good clean.
Seems like different eras of L322 had different trim combinations for the rear window unless I am mistaken. No idea why they age so badly either!
Post #644424 30th Sep 2022 4:59pm
mjdronfield
No, as above, lower window trim never fitted to later cars, only the early ones, without the side trims. They were never fitted together.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #644425 30th Sep 2022 5:03pm
Page 1 of 3 123>
