![]() | Home > General > [SOLVED!] "PARK" / "P" not holding :( |
Yep, policy of neglect (both for car and teeth (rest of body for that matter ![]() Just not had time to stop last couple of months, but work/life balance is improving now ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
I use neutral a lot when waiting at lights etc. Hope this doesn't cause any problems. Similar to what Stan said when left on drive you can hear the engine pushing. FFRR TD6 HSE
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
ive never toke it out of drive at lights just foot on brake everytime "RANGEISM WILL NOT BE TOLERATED"
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35507 ![]() ![]() |
pretty sure you get more vibes with the td6 than the petrol..must be the tractor engine causing it. |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 ![]() ![]() |
thats part of the training on 'defensive driving' - done the course ![]() |
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 ![]() ![]() ![]() |
Had the same problem with my disco 3 stealer fitted a new selector link kit only cost me £30 |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3762 ![]() ![]() |
I can now mark this is solved / resolved, following visit to main dealer.
Have you lubricated the Gear Selector Mechanism under the car next to the Gearbox as set out in another thread on here (by me plus I put in WIKI). If your Mechanism is corroded/Sticky it may not be fulling moving the gearbox into park and therefore leaving you halfway between gears....
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 ![]() ![]() ![]() |
Good result Joe. Glad to hear it s sorted (and cheaply) |
A good thing is that I have now got into the habit of going to neutral then handbrake when I stop at lights etc, instead of just flinging it into PARK. Even doing it on my other autos. Recommend the same to others if not already doing so.
Also just to report that this repair has or appears to have resolved my intermittent "TRANS FAILSAFE PROG" message I was getting, coupled with fluttering in and out of gear, whilst driving along. (Not related to my getting stuck on Low Range problem)
