Home > Technical (L322) > Bank 2 Sensor 1 exhaust temperature sensor |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3763 |
Careful, Bank2 Sensor 1 very rarely reads above 100c.
21st Sep 2022 8:01pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3187 |
I think it's on the 2nd stage turbo exhaust so won't show anything over 100 unless it's in use. 2012 TDV8 Vogue (L322) |
21st Sep 2022 8:04pm |
Thanks JayGee, you have given me a brain reset and agree.
21st Sep 2022 8:10pm |
JoshVogue94 Member Since: 18 Aug 2022 Location: RCT Posts: 55 |
Thanks for the replies guys it must be one of the other 3 sensors then causing the P050E code |
21st Sep 2022 8:15pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1463 |
Pretty sure bank 2 is offside (secondary turbo is nearside) and sensor 1 suggests to me this is the first exhaust gas temperature sensor in the series, which would either be the one on the offside manifold or the one known to be problematic down the side of the EGR.
21st Sep 2022 8:59pm |
Thanks for the reply I've ordered all new seals and some 70mm pipe to replace the 4 intake pipes. Hopefully this will sort the issue. |
27th Sep 2022 4:26pm |
It's worth trying the cheap/free stuff first before the labour intensive and more expensive stuff and all that is good preventative maintenance also! 2015 Range Rover Autobiography 4.4 SDV8 |
27th Sep 2022 7:42pm |
