![]() | Home > Technical (L322) > Abs Sensor |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
I had issues with the same sensor which i used a Genuine RR part for as others has had issues with other makes.
Garymahoo Member Since: 15 Jul 2022 Location: Aberdeenshire Posts: 49 ![]() ![]() |
Thanks Jayk.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
You can get the reluctor rings separately now I think. Had to buy a whole new driveshaft when the ring rusted through on my TD6….
If you can access live data, check the sensor circuit by removing the sensor and waving a magnet across the end of it, if you see a speed signal, then the sensor & circuit is OK and it is the reluctor ring (or the distance the sensor is from it).
Hi guys, Thanks for the replies. Spoke to the reluctor ring folkies and they dont list one although if i can get mine off or know the size they will make one for me.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 870 ![]() ![]() ![]() |
I got my ABS Reluctor Rings direct from UK Parts Direct Ltd in Westbury
