Home > Technical (L322) > Abs Sensor
Garymahoo
Abs Sensor
Hi All (again)
My 2011 Vogue 4.4 Tdv8 is throwing up the Abs light among many others
Mechanic says Rhr abs sensor which i got from Duckworths but non land Rover due to availability. It had to be Delphi.
Still showing the same. Suggestion is now reluctor ring or driveshaft.
Before i go this far i want to ask if anyone has had issues with Delphi sensors?
He did try to remove the driveshaft but i think securely in place was an understatement.
Cheers
Gary
Post #644114 27th Sep 2022 2:00pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
I had issues with the same sensor which i used a Genuine RR part for as others has had issues with other makes.
also another cause is the brake light switch on the back of the pedal again get a genuine part (I got mine from BMW) it looks like this
https://www.eurocarparts.com/search/464110...H0QAvD_BwE
Easy to fit and gives the same error codes as the ABS sensor. If you have a scanning tool you should be able to see if it is the ABS sensor it shows a MPH reading (Well it does in IcarSoft)
By the way my ABS sensor had been broken then glued into place as a bodge, took ages to remove it 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #644124 27th Sep 2022 4:13pm
Garymahoo
Thanks Jayk.
Not sure what software he uses but it is saying Rhr Abs something or other.
I might have a look at the brake light switch as well. Shouldnt be a big job.
I remember seeing a post about a connection through the front wheel arch throwing up various lights also so i will have to have a nosey in there as well.
Blooming cars eh!
Post #644144 27th Sep 2022 7:01pm
mjdronfield
You can get the reluctor rings separately now I think. Had to buy a whole new driveshaft when the ring rusted through on my TD6….
Though they do only list the TD6 here…
https://www.reluctorrings.com/cars/landrover
Might be beneficial to do a bit of research if they want to change the whole driveshaft.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #644147 27th Sep 2022 7:31pm
Phoenix
If you can access live data, check the sensor circuit by removing the sensor and waving a magnet across the end of it, if you see a speed signal, then the sensor & circuit is OK and it is the reluctor ring (or the distance the sensor is from it).
Are you absolutely sure you have the correct sensor for that wheel hub?
Post #644149 27th Sep 2022 7:39pm
Garymahoo
Hi guys, Thanks for the replies. Spoke to the reluctor ring folkies and they dont list one although if i can get mine off or know the size they will make one for me.
Ill have a word with the mechanic about running a magnet accross the sensor.
I hope.the sensor is correct. It came from Duckworths but Land Rover were out of stock with no date of re supply.
Replies are ways appreciated.
Post #644152 27th Sep 2022 7:57pm
pcourtney
I got my ABS Reluctor Rings direct from UK Parts Direct Ltd in Westbury
SKU 309-1 Range Rover ABS Reluctor Ring (L322) Pro Coat V4, I bought two of them, which saved me 25% , so only £13.49 each, saving 25% , and I wanted to do both sides anyway Smile
Fronts
https://www.ukpartsdirect.com/land-rover-r...at-v4.html
Rears
Post #698290 18th Aug 2024 11:26am
