Home > Maintenance & Mods (L322) > Timer for climatization: it is a possible upgrade?
Eddy
Italy 2012 Range Rover Vogue SE TDV8 Java Black
It is not equipped with the heating scheduling function. I would like to upgrade but first I would like to know what parts I need to install and how to update the software to have the function on the touchscreen. Could anyone help me? Thanks in advance
Post #644006 26th Sep 2022 2:41pm
Eddy
Dimenticavo: Vogue l322 tdv8 4.4.
Grazie
Post #644011 26th Sep 2022 2:49pm
S60R
Hi Eddy,
If its like the D4 they all came with the FBH (fuel burning heater) but they charged it as an extra to actually turn it on.
I turned mine on using the IID tool from GAP. No hardware needed to get the functionality within the car. It can then be timed from the main screen....had mine on this morning as I had an early leave!
If you want the remote control that can be added but requires hardware. Very Happy
Post #644021 26th Sep 2022 4:35pm
Eddy
Ottimo!!!
Anche io ho il Gap Id: potresti dirmi I passaggi da fare per attivarlo? Mi faresti un regalo enorme 🙏🙏🙏
Post #644037 26th Sep 2022 7:09pm
Eddy
Optimal!!!
I also have the Gap Id: could you tell me the steps to take to activate it? You would give me a huge gift 🙏🙏🙏
Post #644038 26th Sep 2022 7:11pm
S60R
Perfecto Eddy!!
What year are you?
Try this....
For Range Rover 2005-2009
IIDTool Menu->Car Config->ATC Heat Cool->
Aux Heater is equal to Yes
Park Heater is equal to Yes
IIDTool Menu->Car Config->ACM Audio Control Module->
Auxiliary heater is equal to Yes
Post #644047 26th Sep 2022 7:42pm
Eddy
L322 , year 2012
I'll try tomorrow! That would be really cool
Post #644064 26th Sep 2022 8:44pm
Eddy
I couldn't resist ... I activated the parking heater menus from gap and voilà programmable ventilation appeared on the screen! Fantastic!!!
I managed to start the webasto and the ventilation in the passenger compartment.
One question: are we sure that the water heated by the webasto only goes into the passenger compartment and not into the engine?
I will never stop thanking you, S60R
Post #644077 26th Sep 2022 11:02pm
garyRR
The Webasto also cycles the engine coolant when temperatures are near 0C or below.
Take a look at the forum - there is a guy on here who wired a Bluetooth/wifi switch to allow him to turn on the heater from his phone, to warm up the car in the morning. 2015 Range Rover Autobiography 4.4 SDV8
Post #644078 26th Sep 2022 11:06pm
S60R
Great eddy …. Glad it worked.
It’s a great bit of kit, LR charge a fortune to turn this on and it’s simple to do. As Gary mentions… lots of clever options can be added to give you full remote access now you have turned it on successfully.
Post #644083 27th Sep 2022 6:26am
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
If there are the right modules already in the car, as there are in the MY2010 and up, there is also the option to buy a key fob.
I’ve just been through a lot of faffing about to get the correct combination of module and fob. Thankfully it now all works perfectly ( and just in time for winter ). I may post a thread on what I found worked if that doesn’t duplicate any current threads on here.
In the mean time here’s the link mentioned by GaryRR; https://motor-roam.co.uk/l322-range-rover-...-10-pounds
Note; if you do this I’d suggest using better quality crimped connectors and professional quality crimping tools. TDV8 4.4 2012
Post #644467 1st Oct 2022 9:46am
garyRR
Heatshrink solder connectors are the one! Waterproof, glue to the sheaths and zero chance of disconnection. 2015 Range Rover Autobiography 4.4 SDV8
Post #644473 1st Oct 2022 10:30am
