Home > Technical (L322) > Engine Fault
I used to get the same problem on my M5, limp home mode taking away all that lovely power. Turned out to be the Mass Airflow Sensors, the M5 had 2 of them and they were hellishly expensive, luckily warranty paid but those 2 devices in the airboxes were sending screwy messages to the ECU which then decided to shut everything down to minimise potential damage. Discovery 4 HSE
Post #6361 7th Jul 2009 8:02am
Larry
England 2006 Range Rover SE Td6 Java Black
MAF = Bloody expensive indeed. Especially when you realise they ain't much more than a connector, a plastic body and a metal grid or piece of wire!
Mick, check the engine breathers and throttle body (not familiar with the V8 so don't know the arrangement) for blockages (as per previous post) before you pay the little S#@ts any more money. Crankcase/rocker pressure issues can cause some very wierd and wonderful effects to ECU's (including MAF and knock sensor false failure codes)
Post #6363 7th Jul 2009 8:33am
Mechanics of a car are not my forte fraid to say Larry, should have taken more interest in them when i was younger but was sidetracked by Japs Eyes and Boobies...... Whistle
As i said earlier LR ASSIST Guy deemed it to be broken earth switch in the connector to the fan that cools down the ECU's
Dealership Last week thought it to be ECU
This week they seem to think it is the cooling pump, plus although the same fault is showing on the dash , they are making out that there is an underlying problem, maybe this is because they were paid £414 for whatever they did to the car last week. Evil or Very Mad
2010 Model, more likely Lexus will be getting the dosh ......... Whistle
Post #6364 7th Jul 2009 2:19pm
Larry
Maybe you should try the change 4 random parts idea. Very Happy It does sound more scientific than the LR approach!
Not sure that Lexus are any better than LR, but they certainly can't be much worse!
Post #6366 7th Jul 2009 3:03pm
Confused Confused
Post #6369 7th Jul 2009 3:42pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
One tip I can give you (if you don't already know) about car sensors is that they are rarely unique to a specific vehicle / manufacurer. My other car has had several sensors changed and one of them , the Throttle Position Sensor, appeared to be impossible to get through a dealer etc, but I researched on the net and the Vauxhall/Lotus Carlton number had an equivalent Lucas part number and lo and behold, it was identical to the one used on the old RR 3.5 efi V8 of the 80's/90'. I also found the reverse light switch on the Lotus to be common to the Corvette ZR1 as Chevy, Vaux & Lotus at the time, were all GM owned.
There seem to be 3 main manufacturers of sensors in the world -Lucas , Bosch and Delphi/AC Delco - so if you x-ref their online catalogues, you can usually find your sensor under its original makers guise. Hope this is of use to someone.
Steve Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #6388 8th Jul 2009 10:26pm
It's booked back in again on Mon 13th July they have came to the conclusion that it requires a cooling pump for the ECU's.
Another £483 to supply and fit........... On top of the original £414 previous Labour charges..... Big Cry
Post #6394 9th Jul 2009 9:40am
Larry
Drink as much of the complimentary tea and coffee in the showroom as possible to try to make even for them mugging you for the previous £400. Very Happy
Good luck this time.
Post #6395 9th Jul 2009 2:07pm
Car picked up yesterday, Cooling pump supplied and fitted ...... Big Cry (mugged) so far so good not showing any faults as of yet.
But was told if the problem re-occurs there could be an underlying fault apart from the cooling pump that was fitted Whistle
In other words " We are not at fault if it does re-appear " ........ Whistle
Post #6436 15th Jul 2009 9:06am
Vogue
if it happens again after all this expensive work, does anybody know what is the situation if you refuse to pay the bill saying its their problem for misdiagnosing the problem...
afterall thats what we pay LR main agents for, if we wanted to just replace parts bit by bit a cheap independent could do just that and we could save costs along the way...
Post #6437 15th Jul 2009 11:44am
nbunney
More than likely you don't pay you don't get your car back.
Post #6439 15th Jul 2009 1:28pm
dan_uk_1984
I'm of the opinion that you pay them to fix a problem - if they do not fix the problem they do not get paid!
It depends though, if you have asked them to trace a miscelanious problem then obviously if it takes then 10 hours at £40 per hour then thats what you will have to pay. This is why it helps to have a basic understanding of how your car works before you go to a garage, pull your trousers down and bend over.
Post #6441 15th Jul 2009 2:35pm
Vogue
I once had a Land Rover, the clutch failed under warranty. Shocked
I refused to pay, Rolling Eyes
they said you don't get your vehicle back. Shocked
I said fine neither do you ! Evil or Very Mad
I started to walk out of their reception, their attitude changed somewhat. Wink
It got a little messy, but Trading Standards backed me up 100% - I didn't pay - what was the point in having a golly gee wizz warranty. The stealer said fair wear and tear, I said get lost 6 months old!
Post #6442 15th Jul 2009 4:24pm
nbunney
So the moral is, always get a courtesy car.
Post #6443 15th Jul 2009 5:28pm
