![]() | Home > Technical (L322) > Engine Fault |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 ![]() ![]() ![]() |
I used to get the same problem on my M5, limp home mode taking away all that lovely power. Turned out to be the Mass Airflow Sensors, the M5 had 2 of them and they were hellishly expensive, luckily warranty paid but those 2 devices in the airboxes were sending screwy messages to the ECU which then decided to shut everything down to minimise potential damage. Discovery 4 HSE
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 ![]() ![]() ![]() |
MAF = Bloody expensive indeed. Especially when you realise they ain't much more than a connector, a plastic body and a metal grid or piece of wire!
Mechanics of a car are not my forte fraid to say Larry, should have taken more interest in them when i was younger but was sidetracked by Japs Eyes and Boobies...... |
Maybe you should try the change 4 random parts idea. |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
One tip I can give you (if you don't already know) about car sensors is that they are rarely unique to a specific vehicle / manufacurer. My other car has had several sensors changed and one of them , the Throttle Position Sensor, appeared to be impossible to get through a dealer etc, but I researched on the net and the Vauxhall/Lotus Carlton number had an equivalent Lucas part number and lo and behold, it was identical to the one used on the old RR 3.5 efi V8 of the 80's/90'. I also found the reverse light switch on the Lotus to be common to the Corvette ZR1 as Chevy, Vaux & Lotus at the time, were all GM owned.
It's booked back in again on Mon 13th July they have came to the conclusion that it requires a cooling pump for the ECU's.
Drink as much of the complimentary tea and coffee in the showroom as possible to try to make even for them mugging you for the previous £400. |
Car picked up yesterday, Cooling pump supplied and fitted ...... |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2040 ![]() ![]() |
More than likely you don't pay you don't get your car back. |
I'm of the opinion that you pay them to fix a problem - if they do not fix the problem they do not get paid!
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 ![]() ![]() |
I once had a Land Rover, the clutch failed under warranty. ![]() I refused to pay, ![]() they said you don't get your vehicle back. ![]() I said fine neither do you ! ![]() I started to walk out of their reception, their attitude changed somewhat. ![]() It got a little messy, but Trading Standards backed me up 100% - I didn't pay - what was the point in having a golly gee wizz warranty. The stealer said fair wear and tear, I said get lost 6 months old! |
So the moral is, always get a courtesy car. |
