Home > Technical (L405) > 2014 L405 running light doesn't stay on.
Zwayneg7
United States 2014 Range Rover 5.0 SC V8 Santorini Black
Right side running lights won't stay on when the vehicle is running. They stay on for 10-120 seconds then turn off when engine running. Only the right side has an issue. If the vehicle is not running, the lights stay on as it should... I have swapped lights and tested on other side and no issue with the light as well as tested another light on that side(same result). All other lights function normally. When scanned I do have a right rear daylight fault and cannot be reset, also the actuation test fails and does not work (no light when on). Could it be the BCM? What should I try next, I'm out of ideas. Thanks in advance.
Post #643746 23rd Sep 2022 7:49pm
