Home > Technical (L405) > SmartKey not detected
nwmgc
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Here's a puzzler. I returned last week from a blissfully faultless 1,600 mile round trip to Italy (oh, the joy of covering long distance vs. London crawling).
As I was switching off, a notice came on to say the battery was low in the SmartKey. Fair enough. I changed it, but now nothing on the remote works and I get SmartKey not detected. Humph. I tried a different battery, without success. My spare key doesn't work either (I changed the battery on that, too).
I am now using the actual key to lock and and then starting whilst holding the fob as directed.
Before booking and waiting for the pleasure of a no doubt expensive diagnostic (as everything requires these days), is there something I should be investigating or doing?
Post #642740 12th Sep 2022 8:53am
This maybe very obvious but did you put the battery in the right way round.... Thumbs Up Pete
Post #642748 12th Sep 2022 9:36am
nwmgc
Ha ha - yes! Even I questioned myself...
Post #642751 12th Sep 2022 9:45am
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
On my old Disco 4 I had an issue on replacing the battery that it wouldn't work with a cheaper Energizer battery, I had to buy a decent (more expensive) Duracell Lithium type one and it worked fine then. Just a thought. FFRR SDV8 Autobiography
Post #642757 12th Sep 2022 10:52am
nwmgc
And a good thought, too. I tested the ones I have, but you could well be right - especially if there is a more expensive solution!
Post #642760 12th Sep 2022 10:57am
MrWold
England 2014 Range Rover Autobiography SDV8 Barolo Black
I had the same problem with my Suzuki with Maxell batteries, it worked fine when I put a Duracell in. Chris
2014 FFRR 4.4 SDV8 Autobiography Barolo Black
2012 RRS SDV6 HSE Baltic Blue
and before I saw the light:
2011 Suzuki Grand Vitara SZ5
1998 Ford Mondeo V6 Ghia X
1990 Citroen BX GTi
1973 Triumph GT6
Post #642802 12th Sep 2022 7:31pm
Andy S
The MD I use replaced both batteries FOC, even put them in the fobs for me.
Post #642810 12th Sep 2022 8:59pm
Phoenix
The 'smart key' doesn't rely on battery power, it's essentially NFC technology - similar to that in your contactless debit card.
The battery is only needed for the immobiliser transmit function. The battery warning could be in reference to the KVM module battery, not the key.
Post #642813 12th Sep 2022 9:21pm
Kot
I presume you have placed your smart key in this location? I think once you have used your manual key you need to do this.
https://www.ownerinfo.landrover.com/docume...c/G2165824 2018 SE SDV8 4.4 Byron Blue
Post #642840 13th Sep 2022 8:23am
nwmgc
And the answer is: Duracell. Thanks to all - I should never have believed it, but the key clearly needs the full 3 volts to get it going!
Even then, I nearly gave up until I spotted a child-safe sticker on the back of the battery... Rolling Eyes
Thanks all Thumbs Up
Post #643394 20th Sep 2022 10:54am
