Home > Technical (L322) > Basic oil question.
KitTheRam
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
Basic oil question.
Apologies if this has been asked many times before but what are your brand / spec recommendations for 5w30 oil?
I have just taken delivery of a very well looked after 2009 3.6 TDV8 Vogue with 142,000 on the clock and want to perform an oil and filter change as the last one was done by JLR in January.
Thanks in advance.
Kit
Post #643678 23rd Sep 2022 9:55am
Shell Helix is a great bet sir... Thumbs Up
Post #643680 23rd Sep 2022 10:17am
garyRR
Re: Basic oil question.
Thanks in advance.
Kit
Here you go:
Correct specification is:
5W-30
WSS-M2C913-D
STJLR.03.5003
Any brand conforming to these standards is fine.
Popular oils by users on this site:
Smith & Allan (£70 worth gets you 2x services of oil) https://www.smithandallan.com/product/smit...e-oil-4140
Opie Oils https://www.opieoils.co.uk/service-packs-for-your-vehicle.aspx
Advanced Factors (they have everything you'd need for a full service and are very reasonably priced) https://www.advancedfactors.co.uk/service-...-167-c.asp
OEM oil filter is:
LR002338 OX196/1D1 Mahle (about £10-12) 2015 Range Rover Autobiography 4.4 SDV8
Post #643681 23rd Sep 2022 10:35am
KitTheRam
Thank you both.
Will aim to get Shell Helix with that code.
Last basic question, what’s the correct amount to put in?
Post #643684 23rd Sep 2022 10:54am
garyRR
If you go to the Wiki section of this site, there's a downloadable version of the workshop manual - good to have stored on your computer.
Service fill is 9.5 litres so, I'd check the dip stick and see how full it is before you drain, work out how much you've drained and then put that amount back in, up to a maximum of 9 litres then check the dip stick and adjust accordingly. Sump plugs are only a couple of £ so, it's good practice to put a new sump plug on whilst you're at it.
Quite easy to work out - in off road height, you can normally fit a bucket underneath these cars and most buckets have litre markings in them. To get the most out, have the sump drain facing ever so slightly downhill - either by angle on your driveway or just put a small bit of wood under the opposing front wheel. Leave the driver's door open at all times to lock the suspension in place.
Put some tarpaulin or cardboard boxes down with a 60cm or more radius, to prevent any oil splash or droplets getting on the driveway. Although, a bucket is much higher than an oil drain pan and prevents a lot more splashback than a drain pan would.
Long term consider investing in an oil vacuum. Draper make a good 10L professional one (about £130) and Sealey tools make a 12V pump (about £25). The tubes just go down the dipstick tube to the sump and suck the oil out, with no need to get under the car.
Also make sure you're got the correct oil filter socket size and a small torque wrench which can go as low as the 25-30Nm needed. 2015 Range Rover Autobiography 4.4 SDV8
Post #643686 23rd Sep 2022 11:07am
MOST importantly over and above the great information above is SAFETY SAFETY SAFETY!!! ALWAYS use an axle stand! Even if you leave your wheels on! If there is a catastrophic failure of an EAS component! There is not room under a fatty for me with no air in the EAS system! 👍
Post #643692 23rd Sep 2022 11:34am
KitTheRam
Thanks for all the good advice.
As the car has full main dealer service history from day 1 part of me is thinking to just take it JLR to keep the service paper work looking correct. The other half of me hates overspending. The solution in the middle is going to a respected specialist.
Post #643695 23rd Sep 2022 11:49am
garyRR
The vehicle is 13 years old. It's not worth spending main dealer money anymore.
It's best to do an oil change on these V8s every 5,000-7,000 miles so, I'm my opinion, it's an asset to learn to do it yourself. Everything is easily accessible so, they're a doddle to service. Even a full service shouldn't take you more than an hour.
Keep the parts receipts for services, write on the date you serviced it and mileage and stick it in your service folder! Any respectful future buyer would totally accept this as proof of service history. 2015 Range Rover Autobiography 4.4 SDV8
Post #643696 23rd Sep 2022 11:53am
KitTheRam
Good to know, thanks. Yes I’m someone who owns a few classic cars so know the importance of basic preventative maintenance.
Let’s just say this is the first car I have ever owned that’s been made in the Midlands not Munich!
Out of interest, is there anywhere you guys prefer to buy parts from? Or is it a case of going with the cheapest price for your desired branded part?
Post #643697 23rd Sep 2022 12:00pm
garyRR
The site sponsors for parts:
Advanced Factors
Maltings Offroad (Main dealer who also produce/sell their own OEM parts, not just genuine)
Duckworths (helpful main dealer) 2015 Range Rover Autobiography 4.4 SDV8
Post #643699 23rd Sep 2022 12:11pm
KitTheRam
Thanks.
Appreciate all the replies so far. Will go for one of these two, always been a Castrol man but looking at the Shell option too after the recommend. Interesting it’s listed as a JLR recommend, wonder what they use in the dealerships! Any ideas?
Post #643708 23rd Sep 2022 2:21pm
KitTheRam
Went for the Shell option as found 10L online for £64 delivered and a Bosch filter for £14.
Post #643711 23rd Sep 2022 2:39pm
pcourtney
Hi Kit,
I use Paul Baker ( Broadfields Garage ) , really top guy, but he gets very very busy, oil changes on mine every 5000 miles Smile
BROADFIELDS GARAGE Tel. 01371 872940
HALES FARM
HIGH CROSS LANE EAST
Little Canfield CM6 1TQ
Post #643738 23rd Sep 2022 5:24pm
KitTheRam
Great thanks.
I have spoken to them already, Paul gave me some buying advice.
Post #643739 23rd Sep 2022 5:27pm
kevinp
Does the 3.6 not need low ash oil? The 4.4 needs AF-L shell helix. The one you've shown is just AF.
Post #643742 23rd Sep 2022 6:24pm
