Home > Maintenance & Mods (L322) > Torx bolts spinning in rear height sensor.. |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
To get the best help Sir, it would be handy if you completed your profile to indicate which model Car you have, due to differences with equipment / fittings / fasteners used on various models. ie L322 / L405 |
9th Jul 2022 1:33pm |
Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 74 |
Updated, it is an L322.
9th Jul 2022 1:50pm |
Graculus Member Since: 18 Jan 2022 Location: Holywood Posts: 5 |
The bolts screw into a metal insert which is pressed into the plastic body of the sensor. That insert has separated from the plastic and is now spinning along with the bolt. It won't come out without some "persuasion".
11th Jul 2022 11:46am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3072 |
The parts catalogue for these torx bolts is wrong too... I ordered them for my RR and the bolts that arrived weren't even similar. I never got a solution so cleaned up the old ones and reused them.
11th Jul 2022 11:50am |
Mine definitely had metal inserts and used machine screws, not self tappers.
11th Jul 2022 11:58am |
Thanks all for the help / suggestions.
15th Jul 2022 1:00pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
Do you happen to know what size torx the bolts were? I’m doing my front one… got it off and the bolts are solid and I need the bracket for the new sensor….
22nd Sep 2022 6:40pm |
I got some M6 bolts from Halfords which were too small.
23rd Sep 2022 8:21am |
