Home > Maintenance & Mods (L322) > Torx bolts spinning in rear height sensor..
Rackers
Hi all,
So, what I thought would be an easy job today replacing the rear left height sensor has become anything but!
Got the connector block off, released it from the hanger bracket so I could pull it up into the car to check the length of the wire (all good, thankfully!).
I've tried to unscrew the torx bolts from the sensor and to my surprise, they just spin and spin... Censored
Any recommendations on how I might get them both out bearing in mind the space under there? Or shall I give up and get the pro's to sort it?
Cheers
Post #636463 9th Jul 2022 11:45am
Merchy
To get the best help Sir, it would be handy if you completed your profile to indicate which model Car you have, due to differences with equipment / fittings / fasteners used on various models. Thumbs Up ie L322 / L405
Post #636473 9th Jul 2022 1:33pm
Rackers
Updated, it is an L322.
Thanks
Post #636476 9th Jul 2022 1:50pm
Graculus
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
The bolts screw into a metal insert which is pressed into the plastic body of the sensor. That insert has separated from the plastic and is now spinning along with the bolt. It won't come out without some "persuasion".
As you're replacing them, the easiest thing to do is cut through the plastic body (alongside the bracket) and through the bolt. You should have access with a hacksaw blade or junior hacksaw.
Obviously, you'll need replacement bolts.
Post #636648 11th Jul 2022 11:46am
dhallworth
The parts catalogue for these torx bolts is wrong too... I ordered them for my RR and the bolts that arrived weren't even similar. I never got a solution so cleaned up the old ones and reused them.
There isn't a metal bush in there either (or at least there wasn't on my 2007) as it's a self tapping screw.
If you're fitting a new sensor, get some big self tapping stainless steel screws and use those.
Post #636649 11th Jul 2022 11:50am
Graculus
Mine definitely had metal inserts and used machine screws, not self tappers.
Who knows what's in there! Laughing
Post #636651 11th Jul 2022 11:58am
Rackers
Thanks all for the help / suggestions.
I managed to get a Dremel in the tight space this morning and cut the sensor out Very Happy.
My replacement sensor definitely has a metal bush that takes machine screws.
I also took the opportunity to pull the sensor wiring up into the car through the fuel tank access panel. I've read that some faults are caused by the wires chaffing the tank.
Happy to report there is no damage to the wiring & my adaptive dynamics error is gone Mr. Green
I also treated the car to some new wheel nuts, had to get a 23mm & 24mm socket on the existing ones as some had swollen so much!
Thanks again!
Post #636925 15th Jul 2022 1:00pm
mjdronfield
Do you happen to know what size torx the bolts were? I’m doing my front one… got it off and the bolts are solid and I need the bracket for the new sensor….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #643621 22nd Sep 2022 6:40pm
Rackers
I got some M6 bolts from Halfords which were too small.
I had to purchase these socket cap multi-pack of screws from Halfords: https://www.halfords.com/motoring/tools/fu...82041.html
The correct bolt size from that pack was HEX 5x25mm.
Cheers
Post #643671 23rd Sep 2022 8:21am
