Home > Wheels & Tyres > What the tyre fitter told me. True or not? |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 923 |
Local tyre place asked my mate to put his D3 in access mode before changing his tyres as it was there policy. My mates a mechanic and wasn't happy todo it but said if anything goes wrong it's down to them so did as asked but checked every height setting before leaving and fully tested his suspension.
21st Sep 2022 4:05pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2587 |
Yes, and yes. |
Makes a change from opening the tailgate and putting the hazards on, though. |
21st Sep 2022 4:06pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
Now you know why he is a tyre fitter. |
21st Sep 2022 4:20pm |
MrWold Member Since: 26 Feb 2022 Location: West Sussex Posts: 135 |
Good to know I've not gone senile yet. Thanks guys. Chris
21st Sep 2022 4:37pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 770 |
Complete rubbish. Hope you've re-torqued your nuts.
21st Sep 2022 5:14pm |
My nuts were lowered slackened the next day to the correct tightness. Chris
21st Sep 2022 5:26pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
In the correct sequence I hope!
21st Sep 2022 5:38pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
I always advise them of the tyre pressures & torque setting. It worries me that these large tyre companies still think that they know best - without double checking |
21st Sep 2022 6:05pm |
Whilst on the general subject, the wheel studs should be 'dry' - i.e. no lubricant, if they are lubricated, you can over-torque the road wheel nuts due to lack of friction, conversely, the hub centre should be clean and a free fit, optionally lubricated with a non-metallic lubricant. It's no good if you have to force the wheel on as some of the torque will be 'used up' pulling the wheel onto the hub centre, leaving the wheel nuts under-torqued.
21st Sep 2022 6:24pm |
Yes, all torqued in correct order.
21st Sep 2022 6:56pm |
The |
21st Sep 2022 7:10pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1538 |
I had a front tyre replaced on Monday after it was ruined by hitting a pothole. I told the tyre fitter 1 wanted 35psi (a tad higher than normal as I was about to leave on a 300+km trip.
22nd Sep 2022 4:51am |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1036 |
When LR assist came to sort out a puncture on a motorway hard shoulder I asked about locking the suspension in access mode. Chap said it wasn’t necessary and just slid a trolley jack under the back axle. Used an air gun on the wheel nuts and confirmed the appropriate torque setting by ref to his tablet. So no, you don’t need to lock in access. |
22nd Sep 2022 8:46pm |
