![]() | Home > Technical (L322) > 2011 TDV8 - Coolant drain and fill procedure |
Just drop the bottom hose off, making sure the pressure cap is off of course!
blackpool Member Since: 14 Aug 2022 Location: Blackpool Posts: 24 ![]() ![]() ![]() |
Thanks Pheonix
Just clamp the hose and ease it off the rad., that way it'll empty the radiator and 'gracefully' empty the engine from the top, once that has slowed / stopped, point the hose into your container and open up the clamp to get more out. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
The 3.6 TDV8 has a dedicated drain tap on the radiator and a proper vacuum fill and removal port.
Thanks Gary do you know where I can get a copy of the workshop manual? There are clearly some differences compared to the L405? |
At the top of this forum there's the 'Wiki' link. The link to the workshop manual is in there to download.
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
I recently replaced the thermostat upper/lower housing and all of the hoses with O rings attached to it, through this process I renewed most of the coolant.
Thanks Gary and FFRR14
That is a good question. You'll likely be on the limit. The workshop manual doesn't give any specifications for partial refill for the 2011, it just says total capacity is 14 litres of Texaco XLC.
Thanks again. I am using G12+ Febi. Which I believe is the correct spec. And mixing with deionised water. Never fancy ready mix because never 100% sure you get the true 50:50 mix. |
Febi 19402 G12+ is the correct specification. Mix 50/50 with distilled water.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 882 ![]() ![]() ![]() |
am about to do mine, going to use Holts Speedflush first ( Toolstation is doing it for £4.07 ) for 250ml, only because I have some grey sludge deposit in my coolant tank reservoir, and want to get it cleaned out as much as possible before using the Febi G12+ ( 50/50 mix with de-ionised water)
