Home > Technical (L322) > 2011 TDV8 - Coolant drain and fill procedure |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Just drop the bottom hose off, making sure the pressure cap is off of course!
20th Sep 2022 6:06pm |
blackpool Member Since: 14 Aug 2022 Location: Blackpool Posts: 24 |
Thanks Pheonix
20th Sep 2022 6:13pm |
Just clamp the hose and ease it off the rad., that way it'll empty the radiator and 'gracefully' empty the engine from the top, once that has slowed / stopped, point the hose into your container and open up the clamp to get more out. |
20th Sep 2022 6:34pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
The 3.6 TDV8 has a dedicated drain tap on the radiator and a proper vacuum fill and removal port.
20th Sep 2022 7:03pm |
Thanks Gary do you know where I can get a copy of the workshop manual? There are clearly some differences compared to the L405? |
20th Sep 2022 7:33pm |
At the top of this forum there's the 'Wiki' link. The link to the workshop manual is in there to download.
20th Sep 2022 7:40pm |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
I recently replaced the thermostat upper/lower housing and all of the hoses with O rings attached to it, through this process I renewed most of the coolant.
20th Sep 2022 8:02pm |
Thanks Gary and FFRR14
21st Sep 2022 10:07am |
That is a good question. You'll likely be on the limit. The workshop manual doesn't give any specifications for partial refill for the 2011, it just says total capacity is 14 litres of Texaco XLC.
21st Sep 2022 10:33am |
Thanks again. I am using G12+ Febi. Which I believe is the correct spec. And mixing with deionised water. Never fancy ready mix because never 100% sure you get the true 50:50 mix. |
21st Sep 2022 10:46am |
Febi 19402 G12+ is the correct specification. Mix 50/50 with distilled water.
21st Sep 2022 4:54pm |
