![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 194 ![]() ![]() ![]() |
JayGee - I'd be grateful if you would expand. Do you mean that the DPF is full of ash? I thought this scenario would be highlighted with an error code as I believe that there is a DTC for this, P242F-00. Or do you mean that there could be some other problem with the DPF, that mean it will to function as intended? I've read somewhere on here about someone who's DPF had baked on soot/ash that could not be removed? I had always planned to get my DPF cut off and cleaned properly as a metaphorical 'reset' under my ownership so am happy to continue. I just don't want to do this until I ca be relatively certain that there isn't something else causing an issue 'upstream' as, if so, it would be a waste of time/money. TYIA! ![]() 2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior 2017 Audi SQ5 3.0 V6T Quattro in Volcano Red 2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green. Currently SORN whilst undergoing some serious restoration! |
Is the pressure sensor upstream of the CAT? 2012 TDV8 Vogue (L322) |
I don’t think so. The pressure sensor is the differential pressure sensor shown in the picture at 9. It takes a high pressure pipe upstream of the DPF and a low pressure feed from downstream of the DPF. Although not labelled, I assume the CAT is the cylinder upstream of the DPF?
If the differential pressure is still way too high after it's regenerated (and this seems to be what the OP is experiencing from his description) then you have a DPF problem and not a soot problem. 2012 TDV8 Vogue (L322) |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 335 ![]() ![]() |
Jaygee, I hear you, however I don't agree and I still think the next step is high pressure smoke test. 2012 L322 4.4 TDV8 AB low mileage - a peach
I agree with you both. I’d like to get the smoke test done to rule out anything intake side as that seems like a good and sensible thing to do regardless and would be sensible preventative maintenance noting the age and mileage on the car.
The high pressure reading is my main concern on this. If the pipes were blocked or were leaking it would give a low reading. The only physical way to get a high reading is for DPF to be blocked. I assume it's not reading 3.5v at idle ? 2012 TDV8 Vogue (L322) |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
I would totally recommend Steve at T&S Norman and say it is worth the trip. He will give you a nice Freelander as a runaround if you request.
There's some great info here. I think I am the only person on here to ever replace a DPF and CAT with new after literally taking the engine to pieces chasing this issue. I was £30k and 2 years into it...
I have to admit, there’s a little bit of me enjoying this as I love troubleshooting this kind of problem. I also really appreciate the help and advice as it’s really helping crystallise my thinking.
It's easy to test if your DPF filter is blocked - the off the pipes at each end and do a pressure test. Mine was 0.2 bar yet showing full so Steve Norman knew it was clear. if full it will be over 15bar or stg like that (not sure of the exact reading) |
Dolphinboy is a genius... what a great point.
The soot load has to be calculated from the pressure differential reading in combination with calculated engine load and the estimate of the ash load. In the OP's case where he states there have been only 95 demanded regens this calculation will therefore be way off ( likley due to someone resetting the DPF in software ) and the only reliable data you should be going on is the actual pressure reading. 2012 TDV8 Vogue (L322) |
