![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 194 ![]() ![]() ![]() |
More bad news sadly, but hopefully some light at the end of the tunnel.
Smitch Member Since: 05 Oct 2021 Location: North west Posts: 40 ![]() ![]() ![]() |
Ajmngn - What’s the actual model number on the newly fitted pressure sensor? I can 100% confirm that anything other the the exact revision that came out will artificially read higher levels as the voltages are not the same it MUST be the “AA” revision and not the identical looking “AB” version. |
JayGee - the number of demanded regens is currently 105 and the number of successful regens is 45. There is no field for failed regens that I can see unless called something else? Incomplete regen status is 1, partial successful regens is 0 and regeneration inhibited status is also 0. Obviously these numbers are well down on what I would expect to see for a 103k mile car. It’s almost certainly been reset in order to allow a garage to force a regen and that will be fine as long as they did actually empty the filter of soot when doing so. I’d put money in them doing this but not cleaning the pressure pipes when they did the main part of the filter!
Sorry yes there is no field for failed regens. I'm on a 145k and have 287 successful regens ( doesn't change) and 1123 demanded regens (goes up every time it regens at the 17.9g limit) Resetting the DPF counter is when it's replaced or physically cleaned off the car as it resets the ash accumulation ( i.e the total soot capacity of the PDF)so if a garage did it after a forced regeneration they shouldn't have. Can't see how a blocked sensor pipe would cause a higher pressure reading - it would either show low pressure if it was blocked upstream or the same pressure as upstream side of the DPF if blocked downstream. Hopefully when (previously thought the pic showed your exhaust) it's off the car the garage can solve the issue - good luck |
Just some other points based on my experience with the sensor.
Any update on this Andy? 2012 TDV8 Vogue (L322) |
I do and it's not good news I'm afraid...
Sorry to hear that Andy but it was as I suspected and I have said in the past that forced regens should only be done if absolutely necessary. The DPF consists of a ceramic core to hold the soot and ash and infront of it a catalytic metal element which is use to raise the temps and it's likley this has melted so it's unlikely cleaning will fix it. I'd phone around some scrappers like Gentlemen of salvage and see if you can get a used one. Best of luck! 2012 TDV8 Vogue (L322) |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
guys I've not googled but have you seen any DPF innards melted?
Should be easy enough for the garage to get an inspection camera in there to see. 2012 TDV8 Vogue (L322) |
Sorry for the tardy response. Not much of an update from my last post, however, in the interests of furthering everyone's knowledge:
The reason why forced regens should only be used in an emergency and why it was a return to dealer operation as it would always require additional investigations to identify the root cause of excessive soot and/or failure of the normal regeneration system. 2012 TDV8 Vogue (L322) |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
One stupid idea: what happend if turn around DPF? Other side is brand new. |
