Home > In Car Electronics (L322) > 2010 to 2012 satnav information gathering |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 821 |
in the lower glove box is the USB connector, this is what a dealer connects to when updating maps
16th Sep 2022 4:20pm |
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 |
So ultimately, we're still not further forward for 2010-2012? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
16th Sep 2022 4:23pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2494 |
The connection protocol has until now been described as Firewire although the socket isn't a known Firewire connector. If indeed USB2 then that's a new game. A USB-A plug will fit into the socket if its metal surround is removed so connecting a USB drive is easy. Edit: Re-reading the 1st post I doubt the process is this simple. |
16th Sep 2022 9:37pm |
I have not been able to get my hands on one of these Origin160 drives with the 15cm cable, so there is a possibility that the map data on it could be encrypted, it would be nice to know one way or another, to move the project on a little further |
17th Sep 2022 1:14pm |
Its not unrealistic that a 2-step process is required to obtain the map and then the car's system source the map from an attached drive rather than program the car to interact directly with the map provider. I'll see if the car will recognise a USB stick as to date it has been looking for a device from which to read.
17th Sep 2022 9:07pm |
Fitting a modified USB-A connector to the LR connector doesn't power a USB hub via my modified short USB lead and a USB stick fitted directly to my modified lead isn't recognised as an update device by the Nav update function. The USB stick contained the files of a nav update disc for a MY15 D4 just in case the stick was recognised as an update device.
18th Sep 2022 2:13am |
If it was Firewire (which is full duplex) it would need 6 pins to work, as shown below
18th Sep 2022 12:09pm |
4-wire Firewire has always been supported for peripherals. |
18th Sep 2022 12:20pm |
OK - but if Renesys have not provided Firewire support in the MCU that we use for the TSD ( Touch Screen Display) , how can it use Firewire protocol running over it at Full Duplex ?
18th Sep 2022 12:25pm |
I haven't seen the spec sheet for the MCU so can't comment, but I haven't seen the nav system's pcb either to see what else might be on the pcb. I make an electronic device that uses a particular processor to do most of the work but feed the output though another IC to provide support not available on the main ICs. |
18th Sep 2022 12:39pm |
so they could have added Firewire support to the TSD display pcb, that also has the Renesys MCU on it, highly possible
18th Sep 2022 12:47pm |
I'm reviving my interest in being able to load later maps via the Firewire connector.
8th Oct 2023 9:50pm |
That sounds like a plan. Fingers crossed ! |
9th Oct 2023 9:03pm |
Having been provided with copy of the 2014 LR publication
10th Oct 2023 2:32am |
