Home > Maintenance & Mods (L322) > Battery Change / IID Tool errors from 2024...
Superspoons
Hi all,
Changed my battery over the weekend to an https://www.tayna.co.uk/car-batteries/exide/ek950/ as the 6 year old Bosch which was in there when I bought it finally gave up the ghost.
Then I told the car that it has a new battery via the IID Tool and checked the menu for the correct battery type in another menu.
I then scanned it for errors (pages of them), cleared them and then scanned again.. which has just left the same faults (pages & pages) but loads of then are from the year 2024 (the time and date was set correctly on the car - see below)
Any ideas? Its currently wired up to my Ctek charger as I haven't done any decent miles in it since I fitted the new battery - I did take it to the local shop less than a mile away and it flashed up 'Gearbox Fault' and then 'Active Damping Fault' on the dash..
Vehicle scanned on 04-10-2020 16:12
Using IIDTool BT V3.0 B2643
AAM-Audio Amplifier
B1A01-13 (10) Speaker 1 circuit - General electrical failure - circuit open
( on 26-02-2024 02:56:30 at 0 mi )
- Test Not Completed
B1A02-13 (10) Speaker 2 circuit - General electrical failure - circuit open
B1A09-13 (10) Speaker 9 circuit - General electrical failure - circuit open
B1A10-13 (10) Speaker 10 circuit - General electrical failure - circuit open
B1A03-13 (10) Speaker 3 circuit - General electrical failure - circuit open
etc
ADCM-Active Damping
C101D-26 (50) Front left vertical acceleration sensor - General signal failure - signal rate of change is below the threshold
- Test Not Completed This Monitoring Cycle
C101D-78 (50) Front left vertical acceleration sensor - Mechanical failure - alignment or adjustment is incorrect
C101E-26 (50) Front right vertical acceleration sensor - General signal failure - signal rate of change is below the threshold
C101E-78 (50) Front right vertical acceleration sensor - Mechanical failure - alignment or adjustment is incorrect
etc
Thanks
Gavin Gavin
https://www.youtube.com/@ChallengingClassics
Post #568952 5th Oct 2020 8:44am
Stanley
Hi,
did you ever get to the bottom of this? My IID tool has suddenly started logging loads of faults but I cannot clear them. The car drives fine with no warnings coming up on the dash, just wondering if it is an under voltage issue? i.e is battery and/or alternator on the way out?
Cheers 2011 TDV8 Vogue
1996 4.6 HSE
Post #642858 13th Sep 2022 11:16am
Superspoons
Hi,
This would've been on my old 2010 3.6 TDV8.
From memory, once I'd driven it a bit with the new battery the faults disappeared. I can't remember why the year was wrong though I'm afraid.
Sorry I cant be more helpful. Gavin
Post #642859 13th Sep 2022 11:21am
