Home > Technical (L322) > EGR cooler leak td6 2004 |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Given the robust construction of the egr heat exchanger l would be surprised if that was the source of your leak ( to be proven wrong), the egr thermostat is however a different matter. There’s two possible sources of leaks from the thermostat body, namely the bleed screw and more likely the rubber o ring that connects it to the heat exchanger.
12th Sep 2022 7:14pm |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 220 |
NIce Day thanks, that's encouraging, given the price of the thermostat might as well change it out, i havent got the fluctuating temperature thing yet but it seems to take longer to warm up! |
13th Sep 2022 8:52am |
If you are going to go for changing the engine thermostat, l definitely would, you will need to remove the engine viscous fan in which case removing the egr cooler complete with egr thermostat is straightforward.
13th Sep 2022 3:57pm |
To be honest if it's just the thermostat that's leaking I'll probably leave the cooler/egr in place, rather keep it stock as far as possible.
14th Sep 2022 8:21am |
