![]() | Home > Technical (L405) > SmartKey not detected |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8514 ![]() ![]() ![]() |
This maybe very obvious but did you put the battery in the right way round.... |
nwmgc Member Since: 27 Jan 2014 Location: London Posts: 159 ![]() ![]() ![]() |
Ha ha - yes! Even I questioned myself... |
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 295 ![]() ![]() ![]() |
On my old Disco 4 I had an issue on replacing the battery that it wouldn't work with a cheaper Energizer battery, I had to buy a decent (more expensive) Duracell Lithium type one and it worked fine then. Just a thought. FFRR SDV8 Autobiography |
And a good thought, too. I tested the ones I have, but you could well be right - especially if there is a more expensive solution! |
MrWold Member Since: 26 Feb 2022 Location: West Sussex Posts: 135 ![]() ![]() ![]() |
I had the same problem with my Suzuki with Maxell batteries, it worked fine when I put a Duracell in. Chris
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1053 ![]() ![]() ![]() |
The MD I use replaced both batteries FOC, even put them in the fobs for me. |
The 'smart key' doesn't rely on battery power, it's essentially NFC technology - similar to that in your contactless debit card.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1310 ![]() ![]() |
I presume you have placed your smart key in this location? I think once you have used your manual key you need to do this.
And the answer is: Duracell. Thanks to all - I should never have believed it, but the key clearly needs the full 3 volts to get it going!
