![]() | Home > Maintenance & Mods (L322) > Air-con clutch not engaging |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3246 ![]() ![]() ![]() |
With engine off I got no apparent readings?
No problem - it sounds like the system may well be overcharged unless you're in a high 40's ambient, 10.3 bar is way too high for a 'resting' system as you can see below (1bar = ~14.5psi)
This might demonstrate why the low-side readings are as important as the high-side
I appreciate your replies. Thank you |
Can I check condenser air flow? John
Ah, didn't know of the time difference - airflow through the condenser which is mounted in front of the coolant radiator, would show up as high coolant temperature and / or excessive cooling fan activity.
I’ll have a scout around in the area to see if I can find someone who can do it. |
