Home > Maintenance & Mods (L322) > Air-con clutch not engaging |
Ollie7195 Member Since: 11 Dec 2016 Location: Somerset Posts: 74 |
Hi everyone,
31st Mar 2017 4:00pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
Have you looked at the compressor pulley when the engine is running to see if the clutch is engaged or Not? |
31st Mar 2017 8:33pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
As above, you should see and hear the clutch engaging, if it's not I suspect electrical fault. The clutch is electromagnetic and only moves about 5mm.
31st Mar 2017 9:05pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Same again my clutch never shows up on on my iiD either but works fine. 2008 MY Supercharged
1st Apr 2017 4:28am |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Your A/C System needs regassing. The pressure sensor is only reading 5.667 bar, which is way too low (when the A/C System is totally empty the sensor will still read 5 bar, which is the default) and the electronics will not allow the system to engage the Compressor. Get it tested and regassed, then if no other problems, the system should fire up okay.
3rd Apr 2017 11:31am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
Resurrecting an old thread.
7th Sep 2022 3:59pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
The 3.6 isn't known for so many air con issues so, rule out the easy things first.
7th Sep 2022 5:50pm |
Thank you for the comprehensive reply. Gary
7th Sep 2022 6:09pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Is the 11 bar with the engine & aircon on? Ideally you need a low pressure reading as well to measure the suction and a high pressure gauge to confirm the pressure transducer value. If the pressure relief valve was operating, you'd hear refrigerant escaping from the compressor, 11bar is the correct pressure for ~30 degrees with the compressor running so it could be a thermal expansion valve or blocked filter-drier issue, it all depends on the low-side pressure reading. Blocked condensate drains wouldn't really cause any temperature issues, but would give you damp carpets and a sloshing sound as the condensate swills around the heater box. |
7th Sep 2022 6:44pm |
Peter B Member Since: 26 Aug 2022 Location: Evesham Posts: 31 |
Thanks Gary, my clutch has been unreliable too. Is this something I can trust Halfords to replace or do you think an independent would be safer? Thanks Peter |
8th Sep 2022 9:18am |
If you're sure you need a new compressor, any competent garage should be able to do the job. Halfords may not though due to the time and complexity involved.
8th Sep 2022 9:31am |
Thanks Gary, Halfords diagnosed that a compressor would be required. I have realised that £1,000 doesn't go far when you own a Range Rover..... |
8th Sep 2022 9:37am |
If the clutch isn't engaging then yes, I'd agree. You can get air con compressors refurbished but ultimately, you're talking about a 15 year old compressor - it's not like it's a 1 hour job to replace so, the recommendation is always to replace with new anyway.
8th Sep 2022 9:44am |
I have now logged some of the information from the Gap diagnostics.
8th Sep 2022 12:48pm |
