Home > Technical (L322) > 3.6 TDV8 belt and pulleys
Henrik07
Norway 2007 Range Rover Vogue TDV8 Santorini Black
Hi all!
I've got a squeal coming from the front of the engine, sounds like a dry bearing to me. So I want to replace the belt and all idlers and tensioner pulley. Do any of you know if this is available as a kit? I've trawled ebay and can only come up with a few belts and tensioners sold seperately. It could be I'm entering the wrong search criteria, but right now I don't have a clear picture of which parts I'll be needing. Can't even remember how many idlers there are... Rolling Eyes
Car is a 2007 FF tdv8 LHD
Post #642246 7th Sep 2022 7:40am
garyRR
Part numbers in bold below for the highlighted pulley/tensioner.
 2015 Range Rover Autobiography 4.4 SDV8
Post #642252 7th Sep 2022 8:16am
Henrik07
Excellent! Thank you Gary! Do you know if the idler on the tensioner can be replaced or if I have to replace the complete tensioner assy?
Post #642253 7th Sep 2022 8:20am
garyRR
The tensioner is normally a complete part. 2015 Range Rover Autobiography 4.4 SDV8
Post #642254 7th Sep 2022 8:24am
Henrik07
Thanks again! Now I know what to order Smile
Post #642255 7th Sep 2022 8:26am
Henrik07
Does anyone know if the bearings for the idlers and tensioner can be pressed out and replaced individually? I found a used set of all pulleys and tensioner on ebay and wonder if they can be fitted with new bearings. It would be a fraction of the cost of new ones.
Post #642276 7th Sep 2022 10:26am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Febest list the pulley as a separate part, a look at their photo clearly shows a bearing that looks easy to swap. I have done this on previous cars so I cant see why it would not be a cheap fix if you are not in the UK like me. Please post the part number of the bearing if you do manage to do it.
PQG500160 = Febest: 2987-RRSII
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #642326 8th Sep 2022 12:11am
Henrik07
Ended up ordering the whole shooting match; belt, tensioner and all idlers. I figured it would be worth it for peace of mind and ease of installation.
Thanks everyone!
Henrik
Post #642975 14th Sep 2022 7:58pm
