![]() | Home > In Car Electronics (L322) > Update on Navtool |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312 ![]() ![]() ![]() |
You’ll see from a previous post that I recently installed the Navtool box in my 2008 Vogue. It’s amazing!
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 288 ![]() ![]() ![]() |
Thanks @TYMH I’m currently comparing all the CarPlay upgrade options; it seems this one may be easiest to install! TDV8 4.4 2012 |
Absolutely is. Sam (YouTube) put one in that requires dismantling the head unit to put a new circuit board in. That was 2010 MY anyway… In my previous car (E220) I put an android head unit it which was quite a task and required a plug in dongle to give the CarPlay. It was ‘ok’ and I had it 2 years, but that was nowhere near as good or as easy to install as this. Seriously, the hardest part is routing the audio cable to the back of the centre console from the boot. Tym
… and it was delivered in less than a week from America. Tym
I was weighing up what I needed from the unit, how easy the install was and the price.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3254 ![]() ![]() ![]() |
The Navtool system is different for the post-2009. Have a good look at their website. AFAIK installation is as straightforward but there are, I believe, some differences in operation. For example, I think a remote is used. Suggest you check it all out. For the 2005 - 2009 model years it is excellent . I am delighted with its John 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
8899 Member Since: 23 Aug 2022 Location: Northern Virginia Posts: 3 ![]() ![]() ![]() |
Unfortunately, they do not provide specific installation instructions for the 2010-2012 L322:
rscsmith Member Since: 07 Aug 2022 Location: Sussex Posts: 27 ![]() ![]() |
Hi Tymh
Hi Rob
If you’re just after streaming, blum this in one you your accessory sockets.
Duh! Of course! I should have realised that! |
I bought the Bluetooth thing before I’d picked the car up to make sure I had streaming. Then within a day or so bought the Navtool. I’ve only used the CarPlay side of it so can’t comment on the android auto but if it’s half as good as the CarPlay it will be great. Well worth shelling out for just make sure it’s right for your MY. Tym
Done. $600 poorer than I was, but looking forward to my Android Auto!
There is a twin phono to jack that comes with it but it’s nowhere near long enough to reach the back of the centre console. You can either use a 3.5 extension (hmmmm) or use a longer cable. I used this.
