Home > General (L460 2022) > Autobiography spec not worth the extra money
Page 2 of 3 <123>
Ricky510e
Re this question over the value of the Autobiography trim level.
The primary reason I went Autobiography was that I was forced to do so as you cannot (just checked the Configurator again) have the P510e drivetrain on an HSE.
I wanted the higher power as it doesn’t appear to significantly degrade efficiency, as it will be more able to deal with the heavy car once the battery is depleted.
So, if you want a P510e then you start at ATB and then to very expensive SV, which really isn’t worth the extra in my opinion. Cheers,
Ricky510e
Ordered:
P510e ATB
Silicon Silver, Shadow Pack, Style 5127 wheels
Ebony + Extended Perlino Interior
Deployable Side Steps
Post #641955 4th Sep 2022 4:05pm
Angus
I’ve probably ordered the worse value autobiography out having deliberately ‘downgraded’ some of the spec to get the vehicle I want. However, I’ll have exactly the car I’m after, and I guess it comes down to what you’re prepared to pay. Heart over head etc etc. Mine is fortunately still priced as ordered at launch when I guess the gulf between HSE & Autobiography was closer than it is now.
Post #641965 4th Sep 2022 5:17pm
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
That's a good point Ricky, I hadn't thought about that - I'm guessing JLR have done something to the engine on the P510e to increase the horsepower....... Is that right?
Post #641982 4th Sep 2022 6:46pm
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
You might want to check this - as far as I’m aware, there is no price protection being offered on L460 (or any JLR product anymore).
Post #641984 4th Sep 2022 7:03pm
Eirik34
Norway
The only issue with the P510e AB is that it cannot be delivered with 4-zone climate. Top performance, ultimate spec IMO - except no 4-zone climate.... Not sure if the 3-zone in the P510e AB has fewer vents than others AB variants with 4-zone, nobody seem to have info reg this.
We're still not sure if we should downgrade from our current P510e AB order to the P440e due to lack of 4-zone. Pros and cons...
But the AB is worth the additional premium IMO, leather headliner, SV extended leather, SV carpet mats, meridian signature and the executive seats. AB = The full package (except for the P510e AB variant that doesn't have 4-zone...)
Post #641985 4th Sep 2022 7:09pm
Ricky510e
Hi aja500,
The straight 6 Ingenium in the P440e is a ‘detuned’ version through the engine management ‘black box’.
The P510e engine has the full 400bhp like the P400, but it also has the electric engine, making a gross peak power of 510bhp with the two outputs combined. Cheers,
Ricky510e
Ordered:
P510e ATB
Post #641997 4th Sep 2022 8:28pm
aja500
Thanks for sharing that Ricky, I didn't realise but that's really helpful.
You may recall, I have so little faith in the JLR dealers and the supply of cars that I've actually ordered two variants, one is a P440e LWB and the other a P510e standard wheelbase. Only one will stay with me longterm, but what you've told me there has now made that decision a whole lot easier.
Many thanks Thumbs Up Thumbs Up
Post #642009 4th Sep 2022 9:48pm
Eirik34
Norway
Our dealer says that there are physical (& weight) differences between the straight 6 engines in the P440e and P510e, not just different tuning maps. And that these physical/weight differences affects the ability to provide 4-zone climate in the P510e.
Doesn't the P400 have electrical supercharger in addition to twin turbos? Don't think the I6 in the P440e/P510e have electrical supercharger, only twin turbos? Or maybe the P510e has the electrical supercharger, and the P440e doesn't?
Post #642018 5th Sep 2022 7:14am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Yes, the P400 has a 48V supercharger which the plug-in hybrids don’t. I’d be surprised if there’s much physically different between the AJ300 engines in the two PHEVs.
Post #642025 5th Sep 2022 9:41am
Eirik34
Norway
A bit off topic, but if the only difference between the two I6 (AJ300) PHEV engines is the map tuning, why wouldn't LR offer the P510e in the LWB version as well?
Post #642043 5th Sep 2022 10:53am
Philip
Can’t see that, short of bolting a turbo from a supertanker onto one of them, there will be an appreciable weight difference between two variants of the same single-turbo engine - there will almost certainly be a much bigger difference between the AJ300 and AJ300D, and you can have a LWB diesel.
Post #642048 5th Sep 2022 11:20am
IjM
There is a 40kg+ weight difference between the 440e and 510e vehicles. I can’t believe 3 zone climate is heavier than 4 zone so there must be something else making the 510 heavier. A mapping change doesn’t make any weight difference either. I can’t see any other spec changes that would make a difference either so there surely must be a difference to the engine.
Post #642052 5th Sep 2022 12:43pm
Eirik34
Norway
Agree with you, IjM! There must be some physical properties (& weight) with the P510e I6 engine that prohibit LR from using it in the LWB version, and also prohibits them from using it together with 4-zone climate in the AB trim (4-zone should be heavier/take more space than 3-zone, I guess).
Unless the weight difference between the P510e and P440e is purely related to the Dynamic response Pro (& torque vectoring) hardware that is standard on the P510e??
Post #642055 5th Sep 2022 1:08pm
CS
Bigger battery? Only Range Rovers since 1988
Post #642056 5th Sep 2022 1:08pm
Philip
I don’t know the answer, but (as usual), some of the figures in the spec sheet look wrong - eg. P440e LWB has clearly incorrect maximum vehicle and trailer weight. If correct, there must be also spec differences accounting for the varying difference in SWB vs LWB weights (eg D350 SWB, 2505kg; D350 LWB 5 seat, 2569kg. P440e SWB, 2770kg; P440e LWB, 2810kg).
Post #642057 5th Sep 2022 1:09pm
Page 2 of 3 <123>
