![]() | Home > Maintenance & Mods (L322) > Where is the Air Quality Sensor? |
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 441 ![]() ![]() |
I've bought a new Air Quality Sensor from Dan due to the ECU fault "Air quality sensor line fault" message.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35482 ![]() ![]() |
i think its on the left of the radiator, not sure though.. ... - .- -.
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
On the left of the radiator at the top on the plastic cowl (as you look into the engine bay) there is the first connector, this is for the electronic side of the viscous fan.
Thanks Steve, I used your description and - Eureka, I found it! On the left hand side seen from the front to the engine bay even for a left hand wheeled car. Not that easy accessible with my large hands, though, but I'll manage to replace this. Thanks again! |
Davidmudley Member Since: 26 Dec 2021 Location: Surrey Posts: 80 ![]() ![]() |
I did the same replacement today, and while there isn’t a load of space, taking the right air box out (as facing at the bonnet) and taking off the air pipe nut (see photo) was enough to get an arm in.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Slight technicality here though that David, your car is a 4.4 TDV8, where indeed the sensor is on the back of the radiator housing.
