Home > Maintenance & Mods (L322) > Where is the Air Quality Sensor?
Eirik34
Norway
I've bought a new Air Quality Sensor from Dan due to the ECU fault "Air quality sensor line fault" message.
And according to this thread http://www.fullfatrr.com/forum/topic28100....ity+sensor
this should be an easy fix. But I can't locate the sensor anywhere in the boot!? I've also removed the front grill, can't find the sensor around there either.
Do I need to remove the front lights? Or remove the radiator? Or?
This is a 2007 TDV8 Vogue SE.
Post #372164 13th Feb 2016 2:51pm
i think its on the left of the radiator, not sure though.. ... - .- -.
Post #372166 13th Feb 2016 3:10pm
Eirik34
Norway
According to the workshop manual it should be at the left somewhere (seen from the front), that means it could be at the right for a left hand wheeled (european) ffrr. But I can't locate it....
Post #372169 13th Feb 2016 4:07pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
On the left of the radiator at the top on the plastic cowl (as you look into the engine bay) there is the first connector, this is for the electronic side of the viscous fan.
The connector and the air quality sensor is underneath that.
It might be on the right for left-hand drive vehicles, not sure.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #372241 14th Feb 2016 12:23am
Eirik34
Norway
Thanks Steve, I used your description and - Eureka, I found it! On the left hand side seen from the front to the engine bay even for a left hand wheeled car. Not that easy accessible with my large hands, though, but I'll manage to replace this. Thanks again!
Post #372281 14th Feb 2016 10:38am
ebajema
Thumbs Up Thumbs Up Thumbs Up MY 2010 5.0 SC Galway green and sand interior!!
Post #372283 14th Feb 2016 10:42am
Davidmudley
I did the same replacement today, and while there isn’t a load of space, taking the right air box out (as facing at the bonnet) and taking off the air pipe nut (see photo) was enough to get an arm in.
 Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR
Post #641854 2nd Sep 2022 10:46pm
garyRR
Slight technicality here though that David, your car is a 4.4 TDV8, where indeed the sensor is on the back of the radiator housing.
However, the question was for the 3.6 TDV8. I think the part is the same but access to will obviously be different because the engine is different.
Take a look at this (again on the 4.4 TDV8) to give you an idea of the location and what you're looking for. I think this is the part you're referring to. On the 4.4 TDV8 it's off-centre towards the nearside of the back of the radiator housing.
 2015 Range Rover Autobiography 4.4 SDV8
Post #641868 3rd Sep 2022 10:42am
