Home > Technical (L322) > Rear view camera
Rear view camera
It works but as you can see it looks like it has frost or something on it, the outside of the lens is clean and shiny so not etched, There is no evidence of condensation inside, it's been like this since I bought it and always the same... The yellow lines look in focus so maybe it's a dirty lens inside...
Are these later cameras serviceable, can you take them apart for cleaning..??
Any other ideas..?
Thanks
 Pete
Post #641458 30th Aug 2022 5:47pm
garyRR
If I were to guess, it has condensation inside the lens, because you have no camera feed issue.
I took one apart once and the lens and sensor were all an integral single part so, I think you'd need to change the entire camera PCB inside the assembly.
However, it may be worth taking the opportunity to perform a mod with a better camera. Fit an aftermarket camera hidden on the drop tailgate. The car just takes a standard camera feed so, is easy to splice into. It's permanently live so, if night vision, will need infrared lights with a light sensor otherwise, there will be visible light around the camera all the time. If you have a tow bar, you'd also be able to see it from that angle. 2015 Range Rover Autobiography 4.4 SDV8
Post #641467 30th Aug 2022 7:38pm
Gary,
Thanks for that, I was thinking the same but there are so many cameras available which one do I chose..? What degree vision is the original, is it PAL or the other one etc etc... Pete
Post #641470 30th Aug 2022 8:02pm
garyRR
You can set PAL or NTSC through the infotainment system.
When I fitted an aftermarket camera on my old car (here's the link: https://amzn.eu/d/hwtVpt8 ), it was just a cheap fix I did - I siliconed that camera adjacent to the factory one and it worked fine.
Something like this is very discreet to fit above the numberplate somewhere: https://www.ebay.co.uk/itm/203982644180?mk...media=COPY
I've also seen this - I assume it retrofits into the upper tailgate release button: https://www.ebay.co.uk/itm/123850961620?mk...media=COPY
If I were to hazard a guess, I'd say the stock camera must have an angle around 150 degrees. 2015 Range Rover Autobiography 4.4 SDV8
Post #641471 30th Aug 2022 8:16pm
Thanks, I'll take a look... Thumbs Up Pete
Post #641473 30th Aug 2022 8:25pm
mjdronfield
Can’t see any technical info, but this may save you looking if you replace with another in the same place….
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #641476 30th Aug 2022 8:41pm
mjdronfield
Think this is the rear of the 2010 camera…. If it’s any help…
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #641479 30th Aug 2022 9:03pm
Pete, what camera system do you have? Just a reverse camera or a full visual kit?
Post #641486 30th Aug 2022 10:18pm
It's got the vision pack so 5 cameras, blind spot, High beam assist etc...
Thanks Mark, it's a Ford camera then..! Pete
Post #641489 30th Aug 2022 10:56pm
Ahh, so then you have an Uber expensive camera then Pete… And not replaceable with an aftermarket cheapie!
I’ve never tried to strip a high end camera before! Have done with the cheap 4 wire type. Just not with yours!
Sorry I can’t be any more help sir… 🫢😬👍
Post #641516 31st Aug 2022 8:50am
Cheers Craig, I never use it but the Mrs likes it.... I'll see if I can get it apart....
Do you know why you can't swap it for a cheapy...??
Ta Pete
Post #641519 31st Aug 2022 9:04am
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
The yellow line is superimposed and not part of the camera itself.
It is easy to take the camara apart and service the camera which I have done and refocus the lens whilst at it. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #641536 31st Aug 2022 10:18am
ffrr14
Ta
I have a spare one If you are really stuck. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #641537 31st Aug 2022 10:19am
Ta
Because your camera moves to different views Pete, so change from usual view to fisheye view… You also should have moving parking lines? They should move with steering input on the vision assist pack. You may also get towbar assist on a 322?
So, all this means you have a data lead to the camera rather than the simple 4 wires +- & two video/phono cables…
Post #641542 31st Aug 2022 11:19am
ffrr14, that is a very kind offer, thanks
Craig, thanks for the info....
Well I got it apart and it looks like someone had been playing before as the internal rubber seal had been badly fitted and was pulling the lens away from the camera, a bit of reseating and all seems well...
Maybe not HD but good enough to reverse to
Thanks to all of you for your help... we love free fixes... Thumbs Up Pete
Post #641583 31st Aug 2022 7:08pm
