Home > Technical (L322) > Rear view camera |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8325 |
It works but as you can see it looks like it has frost or something on it, the outside of the lens is clean and shiny so not etched, There is no evidence of condensation inside, it's been like this since I bought it and always the same... The yellow lines look in focus so maybe it's a dirty lens inside...
30th Aug 2022 5:47pm |
Gary,
30th Aug 2022 8:02pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
You can set PAL or NTSC through the infotainment system.
30th Aug 2022 8:16pm |
Thanks, I'll take a look... Pete
30th Aug 2022 8:25pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7829 |
Can’t see any technical info, but this may save you looking if you replace with another in the same place….
30th Aug 2022 8:41pm |
Think this is the rear of the 2010 camera…. If it’s any help…
30th Aug 2022 9:03pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Pete, what camera system do you have? Just a reverse camera or a full visual kit? |
30th Aug 2022 10:18pm |
It's got the vision pack so 5 cameras, blind spot, High beam assist etc...
30th Aug 2022 10:56pm |
Ahh, so then you have an Uber expensive camera then Pete… And not replaceable with an aftermarket cheapie!
31st Aug 2022 8:50am |
Cheers Craig, I never use it but the Mrs likes it.... I'll see if I can get it apart....
31st Aug 2022 9:04am |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
The yellow line is superimposed and not part of the camera itself.
31st Aug 2022 10:18am |
I have a spare one If you are really stuck. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC New Toy: Unimog U1550L/37 New : G350D |
31st Aug 2022 10:19am |
Because your camera moves to different views Pete, so change from usual view to fisheye view… You also should have moving parking lines? They should move with steering input on the vision assist pack. You may also get towbar assist on a 322? So, all this means you have a data lead to the camera rather than the simple 4 wires +- & two video/phono cables… |
31st Aug 2022 11:19am |
ffrr14, that is a very kind offer, thanks
31st Aug 2022 7:08pm |
