![]() | Home > Technical (L322) > 6 Speed ZF TDV8 gearbox rebuilders. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
I think there's a gearbox specialist in Dartford people on the site regularly use.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Dartford Transmissions and Autocare.
IanBoxgrove Member Since: 15 Oct 2021 Location: West Sussex Posts: 12 ![]() ![]() |
Thanks to you both.
Suggest you chat to Martin and tell him what it’s doing and he’ll know exactly what’s wrong. He’s the gearbox guru |
It sounds like the gearbox is behaving more or less normally to me. The ECU is quite advanced on the ZF boxes. It will hold gears when it needs to, including when turning etc.
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
When I got my 3.6 TDV8 I had random harsh downshifts 2 to 1 and rev flare 4th to 5th. I did a Fluid and filter change but also removed the mechatronic body and replaced the bridge and tube seals. Its been butter smooth since. https://www.youtube.com/watch?v=2g-5uY_P7uA
