Home > My Range Rover > She’s arrived
fmgl322
Germany
She’s arrived
Good day chaps,
Thought I’d update you to let you know I am now very much the proud owner of my 2012 Vogue, complete with decent service history, a book of bills and a short list of things to do over the coming weeks.
The good news first: alternator and a/c compressor have already been done, as has the blower motor. Recent bills from the MD were for DPF regens, the previous owner didn’t drive the car much and as such, it was clogging up regularly. I’m a motorway driver and have already noticed the first regen during a drive - that hot exhaust pong on getting home!
The bad news: oily smells, but thankfully nothing dripping on the driveway at home. The oil pipe O-rings are ordered and will be changed as soon as they arrive. Around the oil cooler itself is a bit messy, but nothing is wet with oil, so I’m guessing it’s just old accumulated gunk. A clean up and monitor will tell more… Brakes are a disgrace and will be replaced completely (what’s the current trend for discs/pads?) as will control arms / ball joints up front as she’s a bit jittery and sloppy in the corners and the front tyres are nicely bald on the outer edges. I’m also going to change the rubber hoses as a matter of precaution, there’s a bit of gunk around the hose/throttle body that will need investigating. MAPF is clean though…
Apart from that, not a bad list of problems I think you’ll agree, she’s in perfect nick inside and out and everything works as it should. I’m already averaging 32mpg (mix of country roads and autobahn blasts) and even the mrs has started demanding we take the Rangie when we’re out and about.
Photos to follow once she’s had a good scrub (the Rangie, not the mrs) and polish.
More soon,
FMG
Post #640738 24th Aug 2022 2:19pm
JayGee
Thumbs Up Thumbs Up Thumbs Up
Stock disks are Brembo and no that expensive. Take your pick on pads. Don't be surprised if you also need rear calipers as these often seize. If you have a LR specialist nr it's worth getting them to do a full inspection to see what needs doing immediately and what can be left. Very easy on these cars to spend a huge amount fixing everything when you can run around quite safely with just fixing the major stuff. Buy a GAP IID tool. 2012 TDV8 Vogue (L322)
Post #640752 24th Aug 2022 5:47pm
What JayGee said, and if it were me I'd change all the fluids.... Thumbs Up Pete
Post #640764 24th Aug 2022 8:08pm
fmgl322
Germany
Thanks - fluids are at the top of the list. I've even found (I hope!) a reliable ZF expert (local to me in this part of Germany) to perform a gearbox flush as I don't fancy doing the gearbox myself. Local racers (ie Nürburgring nutters!) all go to him for their gearbox and brake work and his Mrs drives around in an L322. Sounds promising!
Post #640765 24th Aug 2022 8:12pm
DrRob
Fluids - don't forget the power steering. Mine was brown! Now green Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #640813 25th Aug 2022 8:18am
