Home > Technical (L322) > Sunroof not tilt?
Garymahoo
Sunroof not tilt?
Hi All. My.sunroof seems to have a different fault from most.
2011 Vogue. It wont tilt?
One touch opening and closing works fine and it closes fully, But.. when i try to tillt. Nothing. Nada. Zilch. No noise no action.
Tried fully opening with the button and holding for a bit then doing the same the opposite way with no change.
Suggestions anyone?
Post #640688 24th Aug 2022 4:06am
kevinp
I've only used mine once and I found I had to press the switch up, towards the sky, not forward toward the windscreen.
Post #640692 24th Aug 2022 6:34am
Garymahoo
Ahhhhh.
Going to give that a try when i collect it.
Large Marge is at the repair man
Thanks.
Post #640695 24th Aug 2022 7:15am
garyRR
You hold the switch forwards 1 notch for manual close, forward 2 notches for auto close.
For opening, backwards 1 notch for manual opening, 2 notches for automatic opening.
For tilting, press the button in and the sunroof will tilt upwards. To close again, push the button forwards 1 notch for manual or 2 notches for automatic.
If that's still not working, perform the sunroof initialisation procedure:
1. Switch the ignition on.
2. With the sunroof closed, press and release the front of the switch. The sunroof will move to the tilt position.
3. Press the front of the sunroof switch and hold for 20 seconds.
If still no luck, I'd say the switch is faulty and needs swapping out. 2015 Range Rover Autobiography 4.4 SDV8
Post #640698 24th Aug 2022 7:23am
JayGee
I've never opened my sunroof for fear of it not closing again....... 2012 TDV8 Vogue (L322)
Post #640699 24th Aug 2022 7:32am
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
You didn't have a D2 by any chance, did you? Very Happy
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #640718 24th Aug 2022 10:19am
Davlyn
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
Very Happy
Post #640734 24th Aug 2022 12:47pm
