Home > Technical (L322) > Brake pad wear indication |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 584 |
Out of curiosity:
25th Mar 2022 1:50pm |
Thanks.
25th Mar 2022 8:50pm |
Warning had disappeared on its own for a few days. But as expected came back. Raised to off road height, turned the wheel full lock to the left and popped the black connection box open. The pad wear sensor connector was snug, so nothing obviously wrong. Tried jumping the two leads and warning disappeared. So after a little gentle bending of the terminals with a safety pin, reconnected the plugs and all was sorted. |
1st Apr 2022 4:22pm |
Does anyone have a spare brake pad wear sensor plug? Not the one of the sacrificial wear sensor; the one on the car.
24th Aug 2022 6:53am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3241 |
Just short it out and monitor the pads wear visually. 2012 TDV8 Vogue (L322) |
24th Aug 2022 7:44am |
I've thought about it but it isn't difficult to have a working system as this is a minor issue. Just want to stick to the original design. It's just a 2 wire cable and if I can't fix it as it's meant to be I'll resort to some screw down terminal connector. |
24th Aug 2022 8:10am |
