Home > Maintenance & Mods (L322) > Tracking for the L322 2010-2012 TDV8 |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3163 |
Where are you in somerset? I used these guys. very switched on owner from Hungary or Poland. did Aircon too.
18th Aug 2022 6:58pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 739 |
Not sure if they still do it but Kwik Fit did a deal where you got 2 years of checks and adjustments for just over £100.
18th Aug 2022 8:33pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1468 |
I can also vouch for KwikFit doing a proper 4 wheel alignment. 2015 Range Rover Autobiography 4.4 SDV8 |
18th Aug 2022 9:08pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Some may do, some may add bits of cardboard under the wheel pods to get the alignment in spec.
18th Aug 2022 9:24pm |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 194 |
Thanks everyone
19th Aug 2022 7:56am |
(All KwikFit garages use Hunter) 2015 Range Rover Autobiography 4.4 SDV8 |
19th Aug 2022 8:06am |
Thanks Garry, I'll talk to them re the car set up. |
19th Aug 2022 10:22am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3246 |
Hunter is the best but also be aware that adjuster bolts may be seized and the garage may decline to adjust for fear of destroying the nuts and bolts so I'd make sure they are all freed up before booking it in. 2012 TDV8 Vogue (L322) |
19th Aug 2022 10:50am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3106 |
Check with your local Kwik Fit as there are still a few scattered across the country that haven't been updated yet.
19th Aug 2022 12:12pm |
I had one seized so they just did the best they could to get it to within parameters. |
19th Aug 2022 3:00pm |
I would give the boys I linked to a call. Very knowledgable and does a lot of 4x4's. I was really happy with the service (took them over an hour) and the boss is on site so happy to chat to you ref anything. |
19th Aug 2022 3:02pm |
When I had an alignment check the conversation went quickly from we 'need' to align the rears to 'it will be OK as it is' when they saw the adjusters.... 2012 TDV8 Vogue (L322) |
19th Aug 2022 3:59pm |
Good point JayGee
20th Aug 2022 8:07am |
