Home > Technical (L322) > Pitman puller not working for me..... |
Chrali Member Since: 13 Apr 2017 Location: Norwich Posts: 122 |
Thought the pitman puller would work for me, so its really the wrong time to find out my hammers are too wimpy. It was going so well as I'd got all the nuts undone ok.
8th Aug 2022 8:32pm |
Googs Member Since: 19 May 2022 Location: Tassie Posts: 158 |
To be easier on you and your tools you will need this sort of tool for a less painful extraction and also you will need a BFH or a big hammer.
8th Aug 2022 8:48pm |
That#'s a little splitter isn't it? Encourage alternative fuels, use all the petrol!
8th Aug 2022 8:50pm |
I suppose cause we live in different parts of the world it could be called that, but here in Aus we call em a tie rod puller/separator. so yes
8th Aug 2022 8:56pm |
Sorry what I mean, is do I need a 35mm or a 45mm?
8th Aug 2022 8:59pm |
Kezbo1981 Oh I think you are right ! I wasn't happy with how it was going, so I'll defo try it the other way around. Encourage alternative fuels, use all the petrol!
8th Aug 2022 10:11pm |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 |
the way I do mine is to slide a big bar in on the side pick up on something and get someone to stand on the bar that is
9th Aug 2022 10:24am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
Alternatively if you cant get the tool in, undo the bolt holding the arm to the subframe and let the arm dangle.
9th Aug 2022 10:47am |
Cheers guys,
9th Aug 2022 9:42pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
the puller is on wrong 2012 Vogue 4.4 TDV8 - Current
10th Aug 2022 10:21am |
morning chrali i think that might be best the splitter will do the job I would still give that casting a good whack before putting in the splitter. and make sure you put some copper slip on new joint easier next time round new vehicle purchase
10th Aug 2022 10:57am |
Cheers for your help guys, but sorry to say the splitter didn't seem wide enough to do the job Seeing as SWMBO had some hospital appointments over the next few days I had to just connect everything up and I'll get the garage to do it before the MOT this week (least I won't get stung on parts).
15th Aug 2022 10:25pm |
