Home > Maintenance & Mods (L405) > L405 oil change
caymanblack
Thanks Mike. Thumbs Up
Post #638338 31st Jul 2022 12:16pm
supershuttle
I need to get on with this, got the suction pump, got the oil and will warm the engine by going to collect the filter. Where do I insert the probe? Geoff
Post #638342 31st Jul 2022 1:28pm
zenman63
England 2016 Range Rover Autobiography SDV8 Indus Silver
Mine is just a 6L one but it’s not hard to stop halfway to empty.
It was cheap enough on Amazon.
Just needs a longer tube, 10mm diameter.
Post #638353 31st Jul 2022 2:55pm
zenman63
There is a dedicated tube next to the oil filter cap, it twists and pulls up.
Hard to get off if it’s dry.
Suck from that, it works perfectly.
Oil is Castrol edge professional C1 and it’s expensive at the moment!!
Post #638359 31st Jul 2022 4:06pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
use the vac pump units....can do oil changes in this rig in a tux. Main reason I bought 2 of them..........L405's , not vac pumps Laughing 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #639039 8th Aug 2022 2:57pm
supershuttle
Ah well took me a while to do the oil change, pump didn't have 9mm straw and of course the 6mm OD ones don't fit, also instructions were missing. Have raised the issue with supplier.
I did manage but only got about 8.5L out Sad
Would appreciate and help with instructions as I seemed to struggle. Geoff
Post #639046 8th Aug 2022 3:39pm
Baltic Blue
Geoff,
The clear tube from the top of the syphon plug fits directly onto the engine syphon tube.
Post #639057 8th Aug 2022 6:38pm
supershuttle
Thanks Mike, that's the tube that was missing. I think a workaround would be simply to buy some 6mm ID tube and connect it to the other 6mm OD "straws". What about lever positions on top it all seemed to take me ages. Geoff
Post #639059 8th Aug 2022 6:41pm
horse86
my extractor has a few diff sized tubes but it also comes with a black rubber grommet to put on the end. The rubber grommet slides over the oil pipe inside the oil cap reservoir and creates an air tight seal. Sometimes too well and I need to really get a good grip to pull it off 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #639301 11th Aug 2022 2:42pm
