![]() | Home > Technical (L322) > Rain Sensor and new aftermarket screen |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Its not unknown, prepare yourself for a bit of a saga.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Yep, happened to me on my last car.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1543 ![]() ![]() |
It happened with mine, too. Diagnostics indicated the sensor was faulty so I bought another off eBay. While I was waiting for it, I read in the Faultmate help files that it might need a recalibration, so I did that and it worked.
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 451 ![]() ![]() |
I may be in the same boat, Autoglass are turning up today and I’ll be asking them to make sure it works, as they don’t have a Pilkington screen in stock and I need the car back for Monday as I’m off to a wedding!
Googs Member Since: 19 May 2022 Location: Tassie Posts: 158 ![]() ![]() |
Good read, thanks for sharing that. its 5am at moment as soon as it becomes light i will get the garden hose out for testing again! ![]() |
I have use two different scan tools, neither tool mentioned anything about glass being too thick or the the rain sensor has an Auto light sensor in it... I will get the Launch 431X Pros out again and check for recalibration on the program. |
Back again, has any of you used the All Comms to recalibrate the windscreen sensor ? if so could you share your expertise.
Thx SP, Would a spray bottle with water used to test the sensor work? |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 544 ![]() ![]() ![]() |
We have two L322 fatty's, both 2010 and both have had new screens within the last 3 months (bullseyed both of them, virtually in the same place as well). Anyway, Autoglass replaced both screens, on one the auto wipers work fine and on the other they have reverted to adjustable intermittent wipe, odd. Have reported to Autoglass and it's been referred to their warranty dept. so we'll see what happens. Drives:
That's bloody bad luck with the screens mate.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
I pulled the fuse for the rain sensor to convert them to intermittent. |
G’day Graeme, is the rain sensor and the intermittent in the same position, what I mean is if you RR is set to rain sensor and you pulled the fuse did you move the wiper stork to another position? 😎🇦🇺 |
Intermittent uses the same position as auto but the rotational settings change the intermittent delay rather than sensitivity. |
