Home > Maintenance & Mods (L405) > Service notification only 4k after service
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I had the car serviced at a decent indi back in March and the service notification was re-set. About 4 months later and only 4k later, the car is saying it needs another service. Has anyone come across this before?
The DPF sensor was a problem, but this has been fixed a while ago and the DPF regenerates properly now - so I don't believe the problem is oil dilution.
The car is driven steadily, and mostly on motorways, and I can't think of what else could be causing this. It has happened before, when the service notfication came up very soon, though that was when I still had the issue with sensors.
Any help? Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #638646 4th Aug 2022 9:50am
Zebedee
Has no-one else come across this? Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #639120 9th Aug 2022 5:33pm
have you done a forum search? ... - .- -.
Post #639121 9th Aug 2022 5:43pm
Kot
Every time there is a normal active regeneration or if you do a forced regeneration, there is always some oil dilution. The service countdown mileage is adjusted accordingly by the algorithm.
With the 4.4V8 to minimise Active Regenerations. You need to achieve DPF temperature above 250C to maintain passive regeneration that in turn, needs speeds above 63mph but at that speed/temperature, you are just about burning soot, as much as you are producing. At 70mph you can see the soot % dropping gradually. My journeys are on roads where speed limit is 60mph and under so rarely see Passive Regeneration.
I now do at lest 3 to 4 oil changes per year, when the dash/Incontrol app tells me its time. Average 2500 to 3000 miles between oil changes. 2018 SE SDV8 4.4 Byron Blue
Post #639195 10th Aug 2022 3:36pm
Zebedee
Yes Stan - couldn't find anything....
Kot - Quite a lot of my driving is 70mph+ and I do 12k/year, and since the EGR-A replacement all the regenerations seem to be operating normally. Oil changes every 2500 to 3000 miles seems excessive when the oil is the spec (and cost) that it is. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #639218 10th Aug 2022 6:27pm
Kot
Each to their own.
But how do you know the oil is in spec? its not expensive in the big scheme of things, and easy to change yourself with a vacuum pump.
You would need to test the oil to know that its out of spec if you dont believe what the messages tell you.
Or you could just ignore it but running an engine with potential fuel dilution not good for bearings, cylinder lubrication break down then rings failing etc etc
https://www.fullfatrr.com/forum/topic64234.html 2018 SE SDV8 4.4 Byron Blue
Post #639281 11th Aug 2022 11:24am
