Home > Technical (L322) > L322 TDV8 4.4 - Forward Alert Not Available |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1185 |
Have you checked the wires that go to the top of the front suspension struts? if one is broken that also affects the forward alert, the wires are flimsy they were uprated in later cars as they move on top of the struts. |
29th Jul 2022 7:11pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
The other system warnings indicate it may be speed sensor / brake pedal switch or similar cause.
29th Jul 2022 7:37pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7788 |
Can’t see it being the wires to the front struts, as that will throw an Adaptive Dynamics Fault on the dash and the suspension will go rock solid.
29th Jul 2022 8:24pm |
Lardy2333 Member Since: 25 Oct 2020 Location: West Yorkshire Posts: 5 |
Have checked the wires on the struts on both sides and no sign of damage. I'll break out the IID over the weekend and see if that helps to pinpoint the issue. If not, remaining ride height sensor and ABS sensors will have to be ordered. Never a dull moment with a FFRR, eh? |
30th Jul 2022 12:55am |
Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 74 |
Mine always did this when it threw up an Adaptive Dynamics fault when mid drive. It was almost like that error set off everything else.
30th Jul 2022 7:12am |
Right then. Plugged the trusty old IID tool into the car at the weekend which brought up the following
1st Aug 2022 11:59am |
Well, looks like it was as simple as re-calibrating the Steering Angle Sensor. All warnings gone, and the car is purring like a kitten.
12th Aug 2022 3:30pm |
