![]() | Home > Technical (L405) > 4.4 sdv8 2013 problems |
MrWold Member Since: 26 Feb 2022 Location: West Sussex Posts: 135 ![]() ![]() ![]() |
"jeep" ? Chris
E6DYO Member Since: 12 Jul 2022 Location: scotland Posts: 6 ![]() ![]() ![]() |
changed it for you👍 |
That's better. Sorry I can't help though other than to say mine, with good service history and 114,000 miles, doesn't really turn over first, it just fires up. Chris
thanks for your help 👍 |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2567 ![]() ![]() ![]() |
LTB01083 refers to an issue with the electrical connector in the link harness to the fuel pressure sensor. The fix is to replace the link harness and connectors with a new connector for the sensor. |
thank you will give that a look today |
If the connector is the cause then Bosch connector 1928403966 has been suggested as the required part to fit the sensor. |
mlambton Member Since: 30 Sep 2021 Location: Devon Posts: 68 ![]() ![]() ![]() |
I had the same issue last week take a look at the link below. I suspect it will be the same issue. Its a relatively cheap fix too!
fixed turned out to be the sensor on top of the high pressure fuel pump caused by bad fuel |
