Home > Maintenance & Mods (L405) > L405 oil change
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
L405 oil change
Am I missing something here. Always stuck a new sump plug on when I did my L322 oil change, whats a couple of quid. Been looking on the net for an L405 Td6 sump plug....£9 odd plus P&P !!
Gold plated ? Made out of Swan ?
Post #637968 27th Jul 2022 7:50pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
Why? The dealer and shops don’t.
Use a new copper washer and call it a day. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #638072 28th Jul 2022 3:33pm
oil changes on L405's are sucked up nowadays.. ... - .- -.
Post #638075 28th Jul 2022 3:51pm
DaveK
The sump nut now has some sort of rubber o ring moulded in other wise it would be new copper washer
Post #638081 28th Jul 2022 4:55pm
Bora20
What model year? Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #638198 29th Jul 2022 4:11pm
DaveK
2013 Td6
Post #638205 29th Jul 2022 6:15pm
DaveK
Not a fan of this method. How much sludge remains at the very bottom of the sump, building up over the years before becoming instrumental in blocking the turbo oil feeds and leading to an explosion in your wallet ?
Post #638218 29th Jul 2022 9:50pm
Phoenix
None.
Post #638219 29th Jul 2022 9:58pm
Been proven on here many times over the years... Sucking gets 99.9% of the oil out, remove the sump bolt after sucking it up leaves like a 1/4 of a pint! and where the sump drain is means the new oil dilutes the remaining oil almost instantly... Thumbs Up
Post #638232 30th Jul 2022 12:45am
Phoenix
Don't forget there's significantly more oil left in the galleries and oilways, hydraulic tappets etc.
IIRC the bottom of the sump drain is actually above the bottom of the oil drain pickup pipe anyway.
I've removed plenty of Lion & Lion derived engine sumps and never had any 'sludge' in there - which would have to build up to pretty high levels before it was drawn up the oil pickup pipe and into the filter. Maybe in the 1970's but not with engines and lubricants from this century.
Post #638234 30th Jul 2022 7:26am
DaveK
So if you still need to undo the bloody big metal undertray and take the sump plug out , you might as well stick it on a ramp and do the whole job by draining.!
Post #638244 30th Jul 2022 12:31pm
zenman63
England 2016 Range Rover Autobiography SDV8 Indus Silver
I did an oil change yesterday with my new vac pump, so easy to use.
I did also take out the sump plug as I had one to change and an egg cup if that came out.
Post #638317 31st Jul 2022 10:49am
caymanblack
In that case the suck-out method is the way to do it and save the £10 new sump bolt price also. Thumbs Up
zenman what pump have you got? tia.
Post #638327 31st Jul 2022 11:57am
Baltic Blue
You need one with a minimum tank capacity of 10 litres to guarantee no spillage.
I have been using a Draper one for several years now and have been very happy with it.
Post #638335 31st Jul 2022 12:59pm
Kot
Thanks to Mike I also have the 10L Draper it is brilliant and would never be without it now. 2018 SE SDV8 4.4 Byron Blue
Post #638336 31st Jul 2022 1:02pm
